Question about Insignia IS-LCDTV32 32 in. Television
Insignia 32in HDTV
Problem: The picture has vertical seperations (5 or 6). I can not find a local repair person to even look at this brand of TV and BestBuy will not work on it either!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
You have a pwr. supply defect it is sending out incorrect voltage to the inverter,causing scan to malfunction, resulting in a non-linear image..john
Posted on Sep 12, 2007
SOURCE:
No picture, vertical colored lines
I have never heard of a warm-up problem on a digital television. Unlike the old CRT TVs and monitors, digital panels don't have to warm up. I would go with the TV repair persons assessment that you've got a bad panel.
Jan 04, 2018 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Picture won't come up
Insignia is Best Buy's house brand. If it's still under warranty, contact Best Buy. If not, find an electronic repair shop you think you can trust and take it in. There is absolutely nothing you (unless you're an electronics technician) can do to fix it. I know that's not what you wanted to hear, but, that's the way life is now.
Aug 21, 2009 | Insignia NS-L42Q-10A LCD TV
I need the codes for my insignia lcd tv 32in
Remote control codes for your TV can be found here. Search for your TV model number, then click the Support tab. If your remote isn't listed, try codes for the brands listed in the note at the bottom of the page.
Jul 30, 2009 | Philips PM435S Remote Control
About two months ago when we first turned on the TV there were wavy lines across the whole picture. When it warmed up they would go away. Now, the lines are there almost all the time and it's getting...
hi
You are experiencing a lack of vertical deflection or vertical collapse. Since it will come back the first thing I would suspect is “ring cracks” in the solder joint in the vertical circuit, mainly the vertical IC. These suspect solder joint can be re-soldered and the television set repaired.
I would suggest that you contact a local servicer. If you are repairing the set yourself, be careful, there is always a risk of shock when dealing with electronics.
OR
Check your equipment connections. Disconnect your equipment (VCR, DVD or set-top box) from the TV and reconnect, making sure each connection is in tight.
OR
chek this site,i blieve u will b helpfull
http://www.dshosu.com/how-to-fix-toshiba-rear-projection-hdtv-wavy-lines/
regards
Jul 01, 2009 | Toshiba 57H82 57" Rear Projection...
Insignia(samsung) 50" plasma Vertical red lines
I would take it back. I know from purchasing an Insignia LCD from them a while back, the TV just died after about 4 or 5 months. They ended up offering me another TV or with store credit. I took the store credit and chose another TV. I also did not have a warranty. I was told since it was Insignia (which is a Best Buy house brand) that replacing it was not a problem. Good luck.
Nov 25, 2008 | Samsung Televison & Video
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
50 inch insignia plasma
THIS BRAND OF TV IS NOT REALLY RELIABLE AS IT IS ECONOMICAL YOU SEEM TO HAVE A POWER SUPPLY PROBLEM MOST LIKELY A POWER CONTROL BOARD ISSUE .
IT WILL BE MORE ECONOMICAL TO PURCHASE A BETTER BRAND NAME TV AS THE INSIGNIA BRAND PRODUCT IS ECONOMICAL PARTS ARENT AVAILABLE.
Feb 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia IS-LCDTV32 32 in. Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
