I Have a Prescott se/600 UPS, after many years of good service it turned dead, I opened the case and guess what? ALL the electronic components were sanded in order to erase the component ID. I hahve been looking around for manufacturer information or schematics whith no success. What can I do. Thanks in advance Humberto Carrillo hcarrillop@mail.com
5 Suggested Answers
  • 195 Answers
SOURCE: Powerware Personal 1000
Please go to www.powerware.com for manual downloads on most if not all of the the Powerware range of UPS.
Regards
Alan Hood
ami-man
UK
Posted on Mar 04, 2009
  • 68 Answers
SOURCE: Overload LED lit, constant warning tone, no load
you may have to many things plugged into the ups, it is not good to plug a power bar into one of the outlets of one of these as you are OVERLOADING the device with more power than it can produce
Posted on Oct 24, 2009
pravinbhavsa
  • 348 Answers
SOURCE: My UPS Powerware 9120 6kva. At inverter section.
no but I can tell you that for old ups mosfets are used and for new ups IGBT (insulated gate bipolar transistor )are used the IGBTs are not available on shops you have to take help of company
Posted on Mar 08, 2010
  • 7 Answers
SOURCE: 3000 VA UPS Service Manaul of Fiskars Power Systems Make
I have the same PCB on my Deltec PRR2200i. I at least know a few things about the circuit now. I had 11 transistors explode on mine and am replacing them now. Sadly I have not managed to track down a circuit diagram.
Posted on Mar 30, 2010
Powerware5115 will not switch on
A weak or dead battery pack its the main reason of a unresponsive/good health UPS, but never forget to test the electric cord, the fuse and the protective relay.first, this sounds too simple, but thats a common fault.
Battery pack must have at least 5 volts with half amp of current to power up the UPS internal relays, giving electric power to the main switch.
To rise the 12/24 DC volts to 115/120 AC volts, the UPS uses some electronic components (semiconductors) called MOSFETS , and sometimes, blown (browned) MOSFETS on the electric board are the most desastrous cause of a unresponsive (completely dead) or faulty UPS. (I remember that some time ago I see a TRIPP LITE SMART 1500LCD UPS with twelve blown MOSFETS, when happened, that kind of fault must be saw like a little volcano!).
If you know how to take all the safety electric measures, and how to use a portable voltmeter, you can test the voltage/amperage on the battery pack, the electric cord and the replaceable fuse (if has any). Basic and intermediate electronic knowledge is necessary to test MOSFETS and other electronic components on the circuit board.
Aug 09, 2014 | Powerware 9120 UPS System
Can't get any power on the battery side of my ups
If you have had that UPS in service for two years, the battery could be dead in which case the issue of backup power is moot.
Jan 15, 2014 | Energizer ER HM450 (ER-HM450) UPS System
APC PRO1300 F04 CLAMP SHORT ERROR CODE WHAT DOES IT MEAN AND HOW CAN I FIX?
F04 indicates that "Clamp Short" it could be anything, but the word "clamp" reminds me of a varistor / MOV, which is the component that clamps short when there is a voltage surge condition and comes back to its normal state, an open circuit, when the voltage surge is gone. Sometimes it clamps short for good when it is hit by a large surge or just by absorbing and shunting to ground many small surges.
You can brain dead the UPS to check if that resolves the issue. This brain dead test helps to reset the internal circuit of UPS.
1. Disconnect any attached load.
2. Turn off the UPS
3. Unplug the UPS from the wall socket.
4. Disconnect the UPS internal battery.
5. Push and hold the "On" button on the UPS for 5 seconds.
6. Reconnect internal battery.
7. Plug UPS in to known good power source.
8. Turn the UPS ON.
If the same issue remains even after brain dead then you have to replace the UPS. This UPS comes with 3 years of warranty, if it is under warranty you can contact APC support at 800 555 2725
If the UPS is out of warranty then you can participate in APC Trade-UPS program. APC has Trade-UPS program where in you can trade your old unit and get a new unit with great discount. You will also get a return shipping label to ship the trade-in unit to us. You can refer to the below mentioned URL.
http://www.apc.com/shop/tradeups/us/en/tradeups/overview.jsp?agent=a190004&countryCode=us&language=en&userType=endUser&user=21867960&_requestid=105040&_requestid=105040
Mar 02, 2013 | APC Power Saving BackUPS Pro 1300
APC 600 UPS beeping and disconnecting equipment
the batteries would be a good guess
they expand , crack the case and corrode everything around them
Feb 09, 2018 | Computers & Internet
High frequency alarm sounds even when all components are unplugged from unit...even if I turn the unit off. The only way I can get it to stop is to unplug the unit.
You may have a problem with a Flat battery? Try taking the battery out and charging it, or swap it for a known good one, if this will not fix it, then you have a failure within the electronics, if this is so then it will need to be serviced by a professional.
Oct 12, 2011 | APC Back-UPS RS Battery Backup (apw...
Its not starts properly,my batteries are in good condition
Normally if this UPS is in working condition and the batteries are also good, you should be able to start the UPS by just using the battery cabinet. As soon as power is applied the fan must run and the 4 yellow led for battery/load should lit up. If it is completely dead, then a qualified technician will have to check the internal circuit. It has one main board on which all power components are mounted and a separate control board. Generally there is a 80/100 A than goes opened. I hope you can give us more information if the UPS is completely dead or the led comes up
Feb 21, 2011 | MGE Comet EXtreme 12kVA (891012-21) UPS...
Hello Fixia's experts, I have a lil problem wid my U.P.S (Frontech 600) Actually I am using it since 9 or 10 years I haven't faced any problem yet but nowadays it is going completely down whenever there is...
Replacing batteries is really cost-effective replacing the unit is the best choice for a long-term solution although you can go on eBay and assess this yourself. Good luck
Jan 09, 2018 | Compaq R1500 ( 295459-001 ) UPS...
Do active components inside the ups SURT1000UXI get worn out.if yes which component faces this problem quite frequently and solutions regarding that?how to check that component and how to know which...
it will be problem without seeing it physically and more over if you are not familiar with electronics t then please don't try to repair yourself, you might get shock or even dead. if you want to repair yourself then check the mosfet and also battery of your ups. ok
Oct 15, 2010 | APC Back-UPS RS 800VA UPS System
The ups is shutting down immediatly ,once the AC power is off
thats a dead UPS... battery is bad now... you probably need to have it changed...
Jul 09, 2009 | QVS NetStar (UPS650A) UPS System
CP685AVR/BF685 Power Contro.
It is likely the battery. These batteries are designed to last 3-6 years in a UPS. The good news is that if it is the battery, it is completely user replaceable and you'll have a Cyber Power unit that works just like new with a new battery. What may have happened is that the battery was weak, and you may have had a slight dip in the AC power. This caused the Cyberpower unit to switch over to the weak battery which couldn't handle the load. The unit then turned off. When you press the "ON" button, the unit will go through a self-test that checks all of the components and the unit will not turn on and be functional unless all of the components come back with a PASS, including the battery. If possible, test the battery with a voltmeter, it should read around 13.5, but not lower than 11.5v DC. However, with the unit over 3 years old, it almost certainly the battery. Here's a link to a replacement battery for the CP685AVR: http://www.batteryinternational.com/cyber-power-cp685avr-ups-battery-ups-batteries-f1.html
Hope this helps.
Jun 28, 2009 | CyberPower (CP685AVR) UPS System
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
