Question about Radio Communications
Need wiring schematics for mike for harley ultra. plug on end of mike that goes in bike
  • james morgan May 11, 2010
    who makes the radio itself cobra? uniden? midland? and what what type of mic is it?
  • 64 Answers
Take it ti a reputable Cb shop for them to fix.
Posted on Sep 13, 2010
Can it be rewired to have light go off with switch
Harley Davidson Wiring Diagrams and Schematics
Hi Anonymous, for a free wiring diagram please visit the website above. Good luck and have nice day.
Dec 23, 2012 | Harley Davidson Motorcycles
2008 Harley Ultra CVO. When it gets hot the back cylinder spark plug starts missing. Also the power drops considerably. Any solutions?
Hi Anonymous, and the usual suspects are:
1. Plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discarged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. If your bike has a CKP sensor you must leave both plugs in
head and check for spark with a 3rd plug. Good luck and have nice day.
Aug 01, 2012 | 2008 Harley Davidson FLHTCU Ultra Classic...
1997 Harley Ultra Classic blows 10 amp radio power fuse and 30 amp main bike breaker
Hi Anonymous, sounds like you have a hard short between the battery, ignition switch and the radio. For a free wiring diagram please visit the website below:
Good luck
Jul 19, 2012 | Harley Davidson FLHT - FLHTI Electra Glide...
2002 harley davidson ultra glde backfires or coughs through intake
Hi Charles, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at BOTH ends, ignition coil, or plug between ignition sensor and module.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
May 05, 2012 | 2002 Harley Davidson FLHTCUI Electra Glide...
No brake lights or turn signals on te rear of a 2007 Harley ultra Classic
Hi Mike, always check the bulbs first for broken filaments. Then check the connection at the rear fender wiring harness, inspect for corroded, broken or loose pins. Use a dab of dielectric grease and repair as necessary. Check your brake relay if you have one , some models rear turn signals were single filament bulbs only, no running light. If all else fails get out your test light and start tracking the power wire from the harness connection. For a free wiring diagram please visit the website below and good luck:
Sep 24, 2011 | 2007 Harley Davidson FLHTCU Ultra Classic...
Need a spark plug wiring diagram for a 2000 europe harley soortster
Your spark plug wiring shouldn't make any difference as Harley uses a dual fire ignition system. The spark plugs both fire at the same time so it doesn't make any difference which wire goes to the front or back cylinder. This is correct unless someone has changed the ignition system on the bike. However, if you will contact me directly at wd4ity@bellsouth.net , I will scan a copy of a domestic schematic and send it to you. I do not have access to European wiring diagrams but they should be the same as far as the ignition circuit goes. Don't forget to remind me of what you need.
Good Luck
steve
Apr 03, 2011 | Harley Davidson XL 1200 S Sportster Sport...
I need a basic wiring diagram for a 93 ultra classic harley .... i stripped the bike and want to basic wire it
I have a schematic of a '93 FLHS if that will help. Contact me at wd4ity@bellsouth.net and I'll send it to you as a jpeg. Remind me of what you need.
Steve
Mar 22, 2011 | 1993 Harley Davidson FXR Super Glide
Where green wire on starter goes on 1997evo to make the starter button work and what you have to do to fix
The green wire goes directly to the starter. When you look at the end of the starter, you see a pentagon (five sided) shaped piece of metal with three small bolts holding it on. There is a connector at the top of this plate. Thats where the green wires plugs into.
The other end of the wire goes to the starter relay. I am not sure where this relay is located on your bike but I would guess that it's under the seat somewhere. It's a small (about 1 inch) plastic cube. The wire from the starter button actuates this relay which in turn actuates your starter.
Feb 11, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Radio Communications Logo
162 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
