Question about Indesit W 123 Front Load Washer
Indesit WG1234T washer drum not turning
My old but until now trustworthy Indesit WG1234T washing machine has stopped working. It fills and empties OK but the drum doesn't turn or spin, although it will turn by hand. It developed a squealing/scraping noise during the spin cycles the last few times I used it, and I wondered if there was a trapped bra wire although it didn't make a noise when turning by hand and I couldn't see or feel anything poking through the holes. Also the other day I went to put clothes in and there was water in the drum, but I'm not sure if this was because the position of the outlet pipe under the sink had been disturbed or if it is related to the same problem. It hasn't filled with water since while not in use.
Any advice welcome.
  • leading_l964 Apr 19, 2009
    I had the brushes replaced as they were worn right down and at first the drum started to rotate, but when I filled it with washing and the clothes became wet it stopped again.... possibly due to the weight? The engineer thinks the motor was on its way out and couldn't cope with the load and has burned out. The machine is about 15 to 20 years old so isn't worth replacing the motor, so think I will scrap it.
    Thanks for your reply.
  • 85 Answers
Hi there..by the sound of things,the brushes on the motor are worn out.easy to replace,each brush is secured by two screws at the rear of the motor,and will be black in colour,or a reddish colour.it may be easier to remove the motor to gain access.buy a cheap set from ebay,as generally speaking a repair and spares shop will ask four times the going rate.anyhow,once removed there should be at least 7mm of carbon left to make contact with the commutator(the part of the motor that turns)
hope this helps,steve.ps.the belt could have snapped or come off also....
Posted on Apr 19, 2009
Indesit WG1234T - is there a filter and spin cycle not effective
If there is no filter located at the bottom right front of washer behind a re- moveable cover, then you need to remove the rear cover of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should help solve your prob.
Jan 05, 2010 | Indesit W 123 Front Load Washer
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
Drum filling with dirty water
hi as your machine got a non return valve on it to stop water from getting into your machine via waste pipe. worst case is call indesit as i am sure you now get 5 years parts g/tee as indesit is now part of hotpoint still cheaper than another machine hope this helps
Jul 11, 2008 | Indesit W 123 Front Load Washer
Indesit wg1234t wont spin
I also have this common problem with my WG1234T. - The pump still works but the motor no longer spins. The brushes have a ton of life left in them. I tested the motor by connecting directly to power and it spins so the fault is most likely with the 'controller' unit - i.e. the switch/timer device behind the program knob. This device was not really working perfectly before and sometimes caused erratic working but I think it has now died altogether. I'll try to get it to bits to fix it as I don't believe you can still get a replacement controller for this machine.
CJ.
Feb 20, 2008 | Washing Machines
Indesit w123 washing machine
Suggestion: The pipe behind your machine has to have a certain height (the machine drain pipe); it does not go directly into the drain at floor level. Check this out.
May 22, 2007 | Indesit W 123 Front Load Washer
Front Load washing machine
common for the impellor to come off the drain pump also common to have water in the pump rotor housing making the pump fail to start
Oct 13, 2006 | Indesit WA 115 Front Load Washer
Indesit W 123 Front Load Washer Logo
351 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
