Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
What size replacement line for my Ryobi 130r trimmer
The cutting filament ran out on my Ryobi 130r electric trimmer and I want to replace it and rewind the spindle myself. What size line should I buy? Thanks, Rich
  • ryanray1 Apr 19, 2009
    No cord left in so cannot ascertain directionand no arrows to clearly show how top and lower sections of spool are correcy direction of winding ON
SOURCE: Ryobi 105r replacement line
Look at the top of the spool. Line up the two triangles/arrows by turning the inner wheel The inner wheel is a little smaller that the diameter of the spool and has grip lines scored around it. Just below those arrows, on the side of the spool there is a hole where the line would come out of. Thread the line into that hole until it comes out through a hole on the top of the spool. Then bend the end of that line over and stick it in the little hole next to the hole it came through. That will lock it in place. Pull on the other end of the line to tighten it. Now turn that inner wheel and the line will wrap around on the inside of the spool. When it stops and you can't turn it anymore, it's full. Cut the line off about 10 inches or so outside of the spool.
Posted on May 19, 2008
SOURCE: Ryobi Electric string trimmer
TJ, I've had the same problem since yesterday and I found the solution (lots of googling - that's how I found your post BTW).
It turned out that the switch malfunction is a common problem.
The part number for the FA3-4 switch is:
ut41002a-36 ("switch assembly")
Available here (thru Amazon):
http://factorylawnandgarden.com/product/553902/B000PLVCX8/SWITCH_ASSEMBLY_UT41002A_36/
It's a Homelite part, which is identical to Ryobi.
Here is the manual showing it (part 6):
http://www.m-and-d.com/pdfs/ryobi_tool/RY41002.pdf
Here is the thread with the solution:
http://www.ryobitools.com/dc/dcboard.php?az=show_topic&forum=112&topic_id=597&mesg_id=597&page=3
HTH,
Adi
Posted on Jun 25, 2008
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
#1 Taper
  • 1040 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
SOURCE: ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Posted on Sep 04, 2010
Electric line trimmer: line simply cuts off and disappears after a few seconds; can this be that the line is too thin? It is a prewound purchased replacement, so must be wound the right way. Has a...
you can replace the head of the unit as it is bolted on left-handed threads, Lowes, HomeDepot, Wally world, Kmart, basically any discount store sells replacement heads for weed-eaters. hope this helped Tim
Nov 20, 2010 | Ryobi 15" Electric Factory Reconditioned...
What size line does a ryobi CS30m gas trimmer use
The Ryobu CS30 model calls for only .080" line. Other models use larger line and electric models use smaller line.
Oct 03, 2010 | Ryobi Garden
How to install replacement line for a Ryobi 18v weedeater
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
Jul 05, 2010 | Ryobi Garden
Where can I get Ryobi 130R parts?
www.turfparts.com/
www.ereplacementparts.com
www.hammerwall.com
www.m-and-d.com
Jun 30, 2010 | Ryobi 15" Electric Factory Reconditioned...
I have an old 720r trimmer plus ryobi. need to replace the fuel lines. what size is needed
Im not sure on the size I always pull the old ones off and find the matching size,I will however tell you a good trick for installing new fuel lines on trimmers. Get a fine piece of metal wire about six inches long or so (like mig welding wire). You want to take the end of the new fuel line and with snips cut a 45 degree angle so it kind of comes to a point. Next poke the wire through the end you cut and twist it. Finally use the wire to pull the new line through.
Aug 09, 2009 | Garden
Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Jul 05, 2009 | Garden
Replacing fuel lines on ryobi 767r trimmer
Jim
Jul 03, 2009 | Ryobi Garden
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi weed trimmer
I have one of this trimmers. It is simple to replace the line.
-First line up the arrows on the bottom of the spindle.
-Then feed the line back in one of the holes in the side of the spindle (this is the same hole that the cutting string comes out of).
-You will see the line come out of the bottom of the spindle.
-Take that line a place it in the hole on the bottom of the spindle.
-Leave about 9 feet of string hanging out of the weed eater (do the same with the other side).
-Then turn the inside wheel (I can't remember if it is clock wise or counter clock-wise but it will only turn one way) most of the string is rolled into the spindle.
-Cut the string of about 5 inches out of the weed eater. You're ready to cut!
May 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
725 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
