Power goes on and off after it warms up. I have checked for cold solder joint and have not found what is causing the problem.
Comment by VicML, posted on Sep 16, 2007
Thanks
5 Other Users Have The Same Problem
Comment by tuna fish, posted on May 06, 2008
Tv turns off whenever it decides too. Could be after 5 minute, could be after 5 hours, could be after 5 weeks... summer, winter, spring, fall, it doesn't matter. Seems like a design flaw to me if, as someone suggested, it is overheating. Started doing this after about a year of owning it.
Comment by Guest, posted on Nov 21, 2007
turns on and off by itself
Comment by oso231148, posted on Nov 20, 2007
no hace nada no entra en frecuencia la fuente ya le vi el ic que le da señal al regulador y no pasa nada los voltages en el ic estan bien , revise todas las resistencias diodos y condensadores de la fuente, tambien el transistor y estan bien lo unico que revise superficialmentew es el transformador mi mayor problema es que no tengo ninguna informacion , ni diagrama, estoy trabajamdo a ciegas solo con mi logica y creo que me he estancado.
Comment by COASTERS, posted on Nov 16, 2007
MY RCA 27F50T TV WORKS WHEN IT HAS NOT BEEN PLUGGED IN FOR A WHILE. WHEN IT FEELS LIKE IT IT WILL SHUT IT SELF OFF AND TURN IT SELF ON UNTIL YOU UN PLUG IT. SOMETIMES IT HAPPENS RIGHT AWAY OTHER TIMES IT WILL WORK FOR DAYS.IN THE END IT ENDS WITH THAT SAME RESULT. I HAVE TRIED PUTTING BIGGER FUSES BEEFED UP SOME OF THE POWER WIRES CHANGING THE POWER SWITCH. HAS ANYBODY TRIED ANYTHING FARTHER IN DEPTH THAT I MAY BE OVERLOOKING IF SO PLEASE LET ME KNOW.
MARCUS
Comment by srose2006, posted on Nov 13, 2007
My RCA 27F520T turns itself on and off after it has been on for a little while. I cannot find a resolution and have had 0 response from RCA. I purchased this TV from WalMart less than 2 years ago but unfortunately it is now out of warrantee and I was told to contact RCA.
Any suggestions on how to fix?
srose2006@gmail.com
Post a New problem for RCA TruFlat 27F520T 27" TV
Email this problem
