Question about Brother HL-2170W Laser Printer
Toner how do I know when toner needs changing? How can I take the toner or drum out?
Open front cover, remove drum / toner unit. Press release button (it's 'blue' I believe) to separate toner from drum. Replace toner with a new one and reinstall.
Posted on Apr 14, 2009
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Toner life end.
-open front cover
-press 'Option' button
-then key *00 on the keypad
-This resets the device so it knows it has had a new cartridge.
I hope it helps
Apr 11, 2010 | Brother MFC-8860DN All-In-One Laser...
HI, MY XEROX 1045 COPIER has making ""clicking"" sound
That indicates you need to replace the drum cartridge. It's been a while since I supported those products, but I believe the cartridge is in the bottom of the device. Make sure you remove the toner cartridge before tipping it over or you'll have a mess to clean up and won't be able to remove the drum.
Once you replace the drum, you need to reset the copier.
Nov 17, 2009 | Xerox Office Equipment & Supplies
When I replaced the drum I know get a 540 sensor toner error
Get another toner to fit to your new drum, what happens is the toner sits on the drum, and when you lock it on the drum it dumos as much powder from the toner container on top into the drum as it can. If the top unit runs entirly out of toner it will throw the sensor error, if you look at the drum you took out you will see it has the toner in it, so if you even just a put a new one in before you fitted the drum, you will need to fit another..
You can check if this is the issue by looking at the level of powder in drum unit, it should be up to the brim of foam edged slot not below it...then feel your toner if the top cart is empty then thats your issue ..fit another toner
There are other things but this is the most likly and I have given you a test to verify if this is your issue or not.. hope this helps oh and its a good idea not to change toner near drum life ends...or if you dont mind a little mess, before changing drum, invert your old one with toner still on top, while you are holding upside down , keep a firm pressure between both units and unlock the toner, turn upright and you now should have an near emppty old drum and the toner locked back in the toner cartridge ready to transfer its load to the new drum, rather than the expensive stuff heading for the bin......must be money in selling the stuff they want you to waste it....what a planet..cheers.
Nov 15, 2009 | OKI C5100n Laser Printer
I changed the drum unit on my c5500 printer and didn't realize that I needed to replace the toner at the same time. I just replaced that toner about a month ago and now it's saying it's empty - which I...
Before you replace a drum unit, you should (with the top toner cartridge still in place) turn the unit upside down and gently shake the toner that is in the drum unit back into the toner cartridge. When you install toner on these printers, most of the toner falls into the drum unit. The only way you can "reset" the printer is to add more toner, because there is almost no toner in that new drum.
Oct 20, 2009 | OKI C5500n Printer
Brother MCF-7340 first time toner replacement
If this model comes with the drum separately of the cartridge, only replace the cartridge. There's no need to change it every time. until prints start to get lines or dots. Don't expose the drum to light too much.
Jul 30, 2009 | Brother MFC-7340 All-In-One Laser Printer
Changed Toner but its still saying "No Toner"
You may need to replace the drum this time. Usually after a few toner changes the drum needs to be changed to.
Apr 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Toner cartridge needs replacing in brother hl-20
if you want to replace your toner,
First you just need to open your front cover and pull out the toner and drum.
after that, push down the blue buttom on drum and pull out the toner. Then replace the new toner into the drum.
finally, just push back the drum and toner back into the printer.
Apr 01, 2009 | Brother HL-2040 Laser Printer
Printer Problems
Hi, it sounds like you need to change the drum. If you are using the High Yield TN660 toner is your printer, then the drum needs changing every 3-4 toners. If using the low yield TN6300 toner then your drum needs to be replaced every 6-7 toners. Hope this helps
Nov 20, 2008 | Brother HL 1440 Laser Printer
Brother HL-2170W Laser Printer Logo
314 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
