Question about Logitech Cordless Presenter Mouse
What does button on bottom of reciever do....
I have no clue
  • 35 Answers
This is probably used to link the receiver and mouse. If the mouse works, don't touch it :)
Posted on Sep 22, 2007
SOURCE:
I bought a Samsung 65 in flatscreen and the power button on the bottom is gone just wires hanging out will that stop the TV from coming on with the remote.
The missing power button you have on the bottom of your TV is just a manual On and Off switch in case your remote does not work, it has nothing to do with the remote signals at all. Most TV's have a tiny little window or sensor in the front panel which recieves the IR signal from your remote, most IR recievers on TV's have a dark red little window as the sensor.
Feb 23, 2015 | Samsung Televison & Video
Motorola md841 phone states out of range. Have tried unplugging it a new battery and pushing EVERY button:). No change to status
No clue what a SIM is this is a RCA office phone model # 25424RE1.
Batteries are new. Ive unplugged every cord. I have the diplay that works, it show me how many calls ive had etc, but the background wont light up when you pick up the reciever and it wont let me dial or answer the calls.
Oct 19, 2012 | Lands Phones
Won't connect to computer
you should have a reciever that plugs into the pc, and a wireless keyboard and mouse, what you need to do is put new batterys in all the devices, then press the button on the reciever then press the button on bottom of keyboard and same for the mouse.
if you have tried all these things maybe a fault with reciever.
Jun 19, 2012 | Computers & Internet
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
How do i stop the amp frombeing in pcm
At the bottom of the reciever, there is a button labeled STANDARD MODE. Press it and the reciever says PCM. Two buttons to the left is a button marked AUTO/ACL/DIRECT push that a few times and you'll have other options.
Jan 03, 2011 | Pioneer VSX920 71 Channels Receiver
How do I get the mouse and USB working together?
if by usb you mean the little reciever that plugs into your computer. on the bottom of the mouse there is a button, and on the usb reciever there is also a button, press the button on the reciever, it should blink, then press the button on the bottom of the mouse
Jan 15, 2010 | Micro Innovations Wireless Optical Travel...
How do I get my Dell wireless keyboard to work after replacing the batteries?
There should be a small button on the bottom of the wireless receiver and another small button on the bottom of the keyboard. Press the button on the bottom of the reciever first, then quickly press the button on the bottom of the keyboard. This is the connect sequence needed to connect the two devices.
Jan 07, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard and mouse not working
Make sure you have fresh batteries...usually this is how to set up a wireless keyboard and mouse. Insert the reciever in the USB and hit the link button normally located as a recessed button on the bottom, a light will blink....On the keyboard press the button as before located as a recessed button on the bottom. Once linked the reciever light should stop blinking...do the same with the mouse.
Jul 13, 2009 | Micro Innovations Wireless...
I recieved a talkabout 250 and i have no clue how to use it please help
You would need two or more radios to be able to communicate with others. Then you simply press the push-to-talk (PTT) button when you want to talk (transmit) and release it so others can reply (receive). The radios must be set to the same settings to be able to communicate.
Apr 11, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Cordless Optical Mouse Not Working
you need to connect it back to the reciever, everytime you connect the mouse on the bottom it will be looking for the reciever to connect to. Try pressing the connect button on the reciever first then the connect button on the mouse
I hope this helps
Nov 15, 2008 | Logitech Cordless Mouse
Logitech Cordless Presenter Mouse Logo
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
