Question about G-Technology G-Drive (90801101) 160 GB Hard Drive
Beep Sound Problem G-Drive Mini 160gb
I would like to know why my hard drive makes a beep sound when I connect to my Vaio PC laptop trough USB 2.0 port. I can see my hard drive on my laptop, but other PC can read the drive and no beep sound is emited from my G-Drive Mini.
Could you please help me?
SOURCE: beeps and computer not reading USB port
usb drive get faulty. replace it.
Posted on Oct 14, 2008
  • 14 Answers
SOURCE: HD not recognized and makes 3 times beep...beep noise when conect
Sounds like the drive has gone south.
This is a bit of work, but if you have access to a Linux disc, load the Live CD and see if you can mount the drive from there.
This is not quick a quick solution but may be far cheaper than sending off to a recovery expert.
If you are not familiar with Linux, go to www.ubuntu.com and download the latest distro, V9.04. Download, burn a copy and boot from it. Be prepared to spend time doing this, but it may just save your valuable data.
I have many times been able to salvage data just by doing this, if Ubuntu sees the drive, you could copy the data to your C drive and reboot.
Best of luck!
tom
Posted on May 10, 2009
SOURCE: External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Posted on Aug 14, 2009
  • 76 Answers
SOURCE: my external hard drive makes a funny noise when I turn it on
Sounds like the hard drive is having an issue. It may be too late but you can try to freeze your hd and recover the data.
Posted on Aug 25, 2009
SOURCE: maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Posted on Oct 23, 2009
Seagate goflex 500gb not detected giving 3 beeps
I would say if it was spinning when it dropped, you are probably out of luck. There are services available for platter recovery, but they are quite expensive. Practice the 3 backup policy.
Feb 09, 2014 | Seagate FreeAgent GoFlex 500 GB USB 3.0...
Data Recovery Hard Drive Not Mounting
> no beep, click or error sound occur, but the drive is simply not mounting ...
> . I need the data on it
Too late! The disk-drive has "died". Your data is GONE.
Nov 11, 2013 | Western Digital WD5000BMVV 500GB 5400 RPM...
Retriving Data from Storejet and uploading to new computor
If the hard drive in the IBM laptop is OK then remove the hard drive from this laptop. Connect this hard drive to an USB hard drive adapter then connect the USB adapter with the hard drive into the USB port on the Vaio laptop. The Vaio laptop should see it as an external storage device (if the hard drive is OK). You can then open the various folders and files then copy these to the Vaio laptop
Jan 09, 2013 | Transcend StoreJet 320 GB USB 20 Hard...
How to remove beep sound after the system sound?
the beeps ate called post
Then what happens does it restart ? or just wont boot up ?
A bit more information please.
Not sure what you mean by 'when the hard drive beeps
does the hard drive start when you turn the laptop on
(at which point a do the beeps occur a single beep isn't unusual) and it stops when you turn the hard drive off - a beep then would be unusual.
I suspect you don't mean that, & if the laptop is working fine otherwise then I wouldn't worry about it or do you mean something else completely?
make sure the ram modules have secure seatings also check all power and data leads attached from motherboard to hard drive the same will apply for your graphics card
hope this helps
Oct 10, 2012 | Computers & Internet
I have a Sony VAIO GRZ610, old i know. Won't power up,
If you cannot get the laptop working then try this method.
Remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this as an USB mass storage device (external hard drive) and you can open the various folders and files, then you can backup and or transfer your data to another computer. If yiu install the hard drive in an USB hard drive case then you can use this hard drive as an external USB hard drive.
Aug 29, 2012 | Sony VAIO GRZ610 Notebook
Hi.. .... my vaio vgn-n130g cannot find hard drive
First - try to re-seat the harddisk and reboot the computer to ensure the hard drive is connected properly..
If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
Apr 17, 2011 | Sony VAIO VGN-N130G/W Notebook
My hard disk makes a beeping sound when connecting to my mac and it's no recognizable. I already changed cables and ports.
Hi.
Beeping sound means physical damage. Often there is no way to recover data.
Please let me know if you would need some more advice on this.
Regards.
Ginko.
Mar 23, 2011 | Iomega 500GB Prestige USB 2.0 Portable...
When i connect with computer make a beep .all time...i try all usb port.my vista computer dont see.my laptop same dont make noting only beep.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
make sure the usb lead/s have a secure seating and are not bad/faulty
hope this helps
Dec 04, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
My drive was working fine the next day i pluged it in and it just wasent appearing on my desktop is was just making a beep beep beep noise :( please help
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive
good luck
Sep 16, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
G-Technology G-Drive (90801101) 160 GB Hard Drive Logo
1,195 people viewed this question
Top G-Technology Computers & Internet Experts
Piyal Perera
Piyal Perera
dbgreenfield
Level 1 Expert
Mark Schmit
Mark Schmit
Are you a G-Technology Computer and Internet Expert? Answer questions, earn points and help others
