Question about ViewSonic PJ550 Multimedia Projector
Same problem w yellow on viewsonic pj550
Very frustrating: blues are very green, gray is yellow etc. nothing is effected by color adjustment. Appears to be strong yellow dominance.
    Problem Solver:
  • 6 Answers
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Posted on Dec 02, 2009
Danco instructions
Umm, yeah I think so....
Nov 10, 2013 | Danco Home
Green tint
what cable are uusing coumpount vga 15 pin to coumpunt or u try new cables
Jan 24, 2008 | Dell 3200MP Multimedia Projector
I please need a kenwood kvt 516 wiring diagram to hook up my stereo i dont know what each color is. like left fron speaker etc. please help
battery yellow
accessory red
ground black
power antenna blue
amp turn blue/white
illumination orange
dimmer orange/white
RF + gray
RF - gray/black
LF + white
LF - white/black
RR + violet
RR - violet/black
LR + green
LR - green/black
Sep 27, 2010 | Kenwood Car Audio & Video
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
Color problems. last night instantly the color
2 things the cable could be faulty (unlikley)but worth a try
or your lamp is starting to fail
Jun 26, 2010 | Mitsubishi WS-55315 55" Rear Projection...
What is the color code for the wires to the factory radio for a chevy malibu 2004
1989-1990 And Newer
AS VIEWED FROM MATING END OF CONNECTOR
A B C D E F G H I J
K L M N
F Not Used
H Power Antenna Turn On Pink (if available) Blue
Smaller sized
Mar 07, 2010 | 2004 Chevrolet Malibu
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Color
on your monitor press menu button and select degasaus.please rate solution.
May 31, 2008 | ViewSonic 17" CRT Monitor
ViewSonic PJ550 Multimedia Projector Logo
516 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
