Re: i am not able to see any way to plug my ipod to my...
On the top around the back you will see a hole that states "input" this is a 3.5 hole for your male to male jack.
http://www.cobyusa.com/_en/prod_item.php?item=CSMP37&pcat=homeaudio&pscat=speaker_system&pscat2=#
lift the clear plastic and look under the white hinges : ) They are hidden well!lift the clear plastic and look under the white hinges : ) They are hidden well!
You can't post conmments that contain an email address.
Your assessment seems to be correct. The problem is most likely in the iPod.
The stereo headphone connector (called a "jack") may have a broken connection, most likely on the Printed Circuit Board (PCB) inside the iPod. You may try carefully wiggling the plug in the jack and see if the sound comes on and off. Do it with the volume low so you don't damage the amplifier in the iPod.
I have opened them up before. It can be done, but is not particularly easy, and must be done carefully.
If you are technically inclined, or know someone who is, open the iPod and examine the jack connections to the PCB. If there is a break, it can be repaired by soldering a wire across the trace on the board.
If you're not able to do this and don't know anyone who can, it will probably have to be professionally repaired if the warranty has expired.
All you have to do is get a 3.5mm plug to two RCA plugs lead and plug the 3.5 Jack in the headphone socket of your ipod and the two RCA's into an aux imput and away you go. If you get one of the small docks, that will stop the battery running down, but you don't need one.
By the look of the picture on FixYa it looks the RCA's can go in the front socket under the volume control.
The parts required for this are available but difficult to find. The overall repair is not that difficult for anyone that has fixed these before. You'll spend more time getting to the jack than replacing it. Try calling Samsung parts and give them the model as well as the circuit designation of the jack. This designation will be written on the PC board. For less than $5 you should be able to get the jack. Ask a local service shop to install for you and you are off and running.
You can do this a couple of ways, depending on the model of iPod. 1. Almost every iPod has an 1/8" earphone jack. Almost every Receiver has RCA input jacks. At Radio Shack, or any store with an electronics section, ask them for an cable with the 1/8" earphone plug on one end and stereo RCA jacks on the other. Plug the RCA jacks into the receiver, taking note of the name of the input (Aux, iPod, Tape, etc) and plug the other end into the iPod. Set your receiver for the input you're connected to and press Play on your iPod. Enjoy music. 2. From the Apple Store, or any iPod dealer, purchase an iPod Dock for your particular model. Ask the same friendly folks for an audio connection cable and do the same as above for the Receiver end. On the iPod end, just set the iPod into the dock and press Play.
The earphone jack is connected to the logic board, open up your ipod mini and see about replacing the logic board with one from ebay. Easy to do, just be careful.
I think the input is right under one of the legs that swings the cover open. I just looked at mine but can't try it until I get a cord for it. Let me know if that works.
