Incopromm IPN2220 Wireless LAN Card
I have the IPN2220 WLAN Card in my Acer Notebook Aspire 1523 WLMi running with Windows XP.
Since I updated to Service Pack 3, I have problem with the WLAN and cannot connect to my router. I have downloaded the corresponding driver from ACER, but it does not work and have tried all possible settings, but it is a nightmare, it doe not want to work.
Only if I deinstall Service Pack 3 everything is all right.
Is Sercie Pack 3 important?
Would be grate, if I would receive an answer soon.
Bye R.H.
Acer aspire 5310 Wireless LAN indicator light on windows 7
That sort of comes with a OS upgrade, in upgrades from XP to Win 7, I'm supprised that's the only thing that is a issue. I upgraded a old gateway (2005) from XP to Win 7 Pro N 64bit. and had some hardware issues to deal with. Consider yourself lucky. You can get use to it or search endlessly for a fix. Try the Acer forums, you may run across the issue.
Dec 27, 2012 | Computers & Internet
Acer Aspire One will not connect to wireless router
Most Acers use an IPN2220 Wireless card. If yours does, you use XP, and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you discribe
Jan 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
My Acer aspire one was working on BT broadband wireless but now is no longer connected. I have tried re-installing but it cannot find the hub.
Most Acers use an IPN2220 Wireless card. If yours does, you use XP and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you discribe
Jan 06, 2010 | Acer Aspire One PC Notebook
ACER Laptop will not update networki adapter. Was having trouble running Windows xp and had to reinstall it. now I need a disk to update my adapter but I bought this used and I do not have the disk....
http://gd.panam.acer.com/home/ enter your laptop information as it asks select your operating system, and it will display all the drivers available for you. you can then download the ones you need and be set.
Dec 17, 2009 | Acer TravelMate 4202WLMi Notebook
I don't have any internet connection an mine acer notebook. The wireless is working fine. What can i do??
Most Acers use a form of Intel IPN2220 Wireless card. If yours does, you use XP and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you describe
Oct 14, 2009 | Acer Aspire 5100 Notebook
Driver for wireless lan, for xp
I assume the LAN card is built-in therefore
Go to the Acer WEB site to download the drivers you need, make sure it is Windows XP or Vista version for your particular MODEL laptop.
Use this link :-
http://global.acer.com/support/download.htm
Apr 14, 2009 | Acer Aspire 5315 Notebook
No wireless LAN after formatted
Most Acers use an IPN2220 Wireless card. If yours does and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you discribe
Feb 24, 2009 | Acer (D10709-002) (D10709002) 802.11g/b...
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
248 people viewed this question
David Payne
David Payne
