My 2 usb ports on my monitor not working
Hello my 2 usb ports on my dell 1907FP monitor is not working. When I plug stuff in it I get nothing it won't recognize the device. They both have worked in the past I think what happen was the devices that was in both port was just pulled out and not closed out properly. This has happen once before but I can not remember how it was fixed can you please help I need to get these ports working again ASAP.
  • giles1328 Apr 13, 2009
    Hey thanks for the info Sutchman & dante777, but I forgot to ask one other question. How can I tell which is the right USB ports in my device manager for the two that is for my monitor that I need to fix? It shows 5 Standard Enhanced PCI to USB Host Controller, 1 unknown device, and 5 USB Root Hub in that order from top to bottom.
    President:
  • 623 Answers
In order for the two USB ports on the monitor to work, the monitor itself has to be connected to your computer via another USB cable with connectors that look like this:
The flat connector goes into an available USB port on your computer, the square one plugs into your monitor. Check if your cable is connected properly or exchange it with another one.
To eliminate that there is something wrong with your "not recognized device", plug this device into another USB port of your computer. The reason to preferably remove the device safely in Windows is that you can loose data if you just unplug it. If it is an external harddrive, it can get damaged, because you interrupt the power and the read/write head can get "stuck". So check this device on another computer or USB port.
If you have any other questions or something is not clear to you, just come back here and leave a comment and I'm happy to help.
Posted on Apr 13, 2009
  •  C. Dante
    C. Dante Apr 13, 2009
    You can leave the Host Controller alone. Nothing to d here.
    Open the Device Manager and plug in your device into the monitor.
    Windows will show "unknown device" and the "Found New Hardware" tray info. If it is a USB stick, it should fix itself (at least in WindowsXP.) If it does not go past the "unknown device" stage, you might need to install a driver for whatever you plug in (also for Win2000 and 9x).
    Enlighten me: what are you trying to connect?
    The one in question is very likely the one that has the yellow question mark. Cameras, Bluetooth adapters etc. have to have the software installed before you connect the device to the computer, because otherwise Windows will try to install a generic driver, which often fails.
  • 48 Answers
I'd try deleting them through Device Manager then reboot and if it doesn't find them, rescan for devices.
Dell LCD 1907FP 19" have
Unfortunately this is an early indicator that the LCD display panel is starting to break down and the cost to replace the part will exceed the amount of a new monitor. I recommend using present item until it completely fails. Sometimes the video cable is the issue and should be subbed provided you can detach from both ends.
Sep 06, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
I do not know how to make my dell monitor usb ports active please help me
  • Check that your monitor is turned ON.
  • Reconnect the upstream cable to your computer.
  • Reconnect the USB peripherals (downstream connector).
  • Switch off and then turn on the monitor again.
Jan 19, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
Nov 20, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Dell 1907fpf will not power on.
Please search for "Power button stuck on Dell 1907FP" and see the advise from other members. I solved my by following their instructions.
Feb 15, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
USB outlets
I'm assuming you are speaking of the USB ports on the Monitor?
Do you have the USB cable running from the back of your computer to the back of your monitor? For those ports to work, you need a USB cable that runs from the computer to your monitor. This is a cable in addition to the power cable and the video cable. Verify you have three cables connected.
If you are not speaking about the USB ports on the monitor, please advise...
Aug 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907fp USB port not working
The big question is do you have the USB uplink cabled from the monitor, connected to a USB port on the system?
http://support.dell.com/support/edocs/systems/1907FP/en/about.htm#Bottom%20View
Item #5 needs to be connected to your system's USB port via a USB cable. The ports on the monitor are just a USB hub.
Jun 09, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907fp picture "shifts up"
It is most likely the cable, it is where most faults of this ilk lie in LCD monitors. :-)
Mar 27, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Side USB ports
You need to connect a USB cable from your PC to the USB port under the monitor.
It is a standard usb cable used by printers with a flat plug on one end and a squareish plug on the other.
You should also have 2 more usb ports under the screen as well. There are normally 4 on Dell screens. 2 side, 2 under, and the one square plug to connect to the PC.
Feb 20, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Computers & Internet Logo
10,958 people viewed this question
David Payne
David Payne
