Very low sound from all channels
The problem i am having is that although everything on the unit works perfect there is very little sound coming from the speakers to the point where you have to put your ear right next to the speaker to hear sound coming through it. everything else on the unit works fine and it does not blow fuses. This unit was costly in its day and i would like to get it fixed or know maybe some ideas as to the problem? Thank you michael
  • 3 more comments
  • Risso Nov 15, 2007
    I Bought a new sony HT DDW700 and very low sound from all channels problem. I have tried to configure it many times, tried to configure it manually, but you have to go to its 3/4 of the volume to start hear something.
  • ccorreia Nov 23, 2007
    I have the coby dvd 755 the speakers work perfectly when watching a dvd but on regular tv they are ver low please help
  • Hunter27 Nov 27, 2007
    I just got the durabrand home theater system, model # sts96 and everything works fine except for the sound. there is very little sound coming from the speakers and the sub.
  • efarris3 Feb 14, 2008
    i have a sanyo dwm 3900, it seems to be stuck in bypass mode, and when i have it in the english settings there is very faint voice, but the background noise is normal, but when i use the french and spanish voive settings everything is fine, what should i do.
  • robertodiaz Apr 30, 2008
    very low sound from all channel problems
Have you tried changing the settings via the LEVEL button on the remote for EACH INDIVIDUAL SPEAKER?  Hope this helps!
Posted on Oct 26, 2007
One other solution is that the reciever has a "pre-out" and "main in" connection on the back meant for an external EQ to be hooked up, without the EQ you need to put jumpers from the outs to the ins
Posted on Oct 12, 2007
  • 752 Answers
Without a model # it's hard to say what you have or what the problem might be, but since you said "in the day" I'll assume it's old enough to have a tape monitor function... Make sure Tape Monitor 2 is not on. Also make sure you are on the correct A/B setting.
Posted on Sep 13, 2007
  • Mitch
    Mitch Oct 08, 2007
    If you rated my answer unhelpful because you tried the suggestions to no avail, then it leaves only one possible alternative. The amp output transistors are shot and will need to be repaired by a knowledgable shop.
    Please alter the rating to reflect that your question is resolved.
Receiver Marantz SR 930
When the unit detects a problem, it shuts itself off to prevent any further damage. Your outputs (the IC's that give you sound) are most likely bad. You would need to know how to solder, etc. to replace them. Your best bet is to take to a repair shop if you can find one...
Apr 15, 2014 | Audio Players & Recorders
I have a cable running from my set top box to another tv. Although i have a good picture there is not enough volume on the sound. It has worked perfectly well until I had to dismantle everything . I have a...
This is not how you explain your problems to others. It should be precise. In this case, you could have said that you connected the cable between the RF out put of set-top box and RF input TV. Or Audio/video output of set-top box to Audio/video input of the TV. Also you did not mention, to which port you had connected the Vedeo recorder and DVD which are working good. Now, it may the volume level of the set-top box at low level which you can try to increase by using the remote control
If you could not sort out the problem explain how you had 'dismantled everything'
Apr 12, 2011 | Sharp 25N-M100 25" TV
Vestax o5 pro mixer channel 2 not working
Doe you get sound in from the headphones? If so, then the issue might be the volume fader for that specific channel.
If not, then the issue might be the input connections or input pc board the connections are soldered on to.
The fader can be self replaced, although complete disassembly of your unit is required. Not a hard task, but there are alot of jumper cables, and you have to be careful when putting her back together.
If it's the latter, then I would suggest taking it to a service center for repair.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Dec 20, 2008 | Sony PS-LX250H Turntable
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
Old Turntable Philips
You may have a bad stylus (needle), it can cause just that type of problem. Find a service center near you and see if they can get a replacement for you. They are very easy to replace, but very difficult to find.
Hope this helps.
Dave
Jun 30, 2008 | Audio Players & Recorders
No sound in rear speakers
I figured this one out, although I might still send it back for an exchange. It turned out that the right rear speaker works just fine, however the jack seems to be flawed. When fully plugged in, the rear speaker input only picks up the left channel. If you pull it out just a little, say 1/8-1/4 the way out it will pick up both channels. Not a good solution but it works for the time being.
Jun 03, 2008 | Razer Barracuda HP-1 Consumer Headphones
No Sound Through Speakers
Hi Jake,
If you haven't done so already, I'd try double checking the speaker wiring, you may have some exposed or badly kinked wires behind the unit.
Cheers,
Matt Coyote
Feb 20, 2008 | Car Audio & Video
294 people viewed this question
 Grubhead
Grubhead
