Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher paykel washer
My fisher paykel of 6 years or so will not rinse or spin. It agitates but will not spin the clothes? I have only tried what my book says which is virtually nothing and that is what it is doing too? Help--I have a teenage daughter who washes alot of clothes.
  • sukiesue Nov 03, 2007
    will not drain or spin
  • bfsam Sep 26, 2008
    I have the fisher paykel eco smart washer and dryer. the washer will washer but will not pump the water out and will not spin, the pump was also leaking a little. It starts to let the water out but after just 5 seconds it stops dead. mine is 3 years old and have extended warrenty. called them to repair it, that was 9 days ago. they have not received the pump from fisher paykel yet. they called them and fisher paykel don't know where the order went. fisher paykel don't even know how it was shipped or the traceing number. I have 5 people here and need my washer. Might I add mine is a GWL11
    Scholar:
  • 146 Answers
The drain pump is jammed. Switch off and remove the plug from the wall socket. Tilt the machine back so you can look under it. On the right you will see a motor which looks like it is upside down. This is your drain pump. Remove the wiring harness from the pump and turn the pump clockwise while pulling back the little white plastic clip which holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
  • mkrajcir
    mkrajcir May 06, 2012
    This worked for us! We were able to clear this pump and now it works just fine. Thanks so much for posting this. It saved us an expensive visit from a repair man. This made my day today! THANK YOU!
  • 3 Answers
This is great it works and saves a $100 service call. I will be doing this about every 3 years as a maintenance item. Just one note to clarify things.
After pressing the little white clip, you have to twist the whole motor assembly COUNTER clockwise about a 1/4 turn. It then will pull straight out. You will see a mouse-sized ball of fuzz that has knocked itself together and is plugging the drain. Just pull the fuzz out. Then put everything back the way it was before. Be sure the motor assembly is correctly and fully twisted back into place; otherwise, it won't be completely sealed and you will have a water leak.
Posted on Jun 01, 2010
Thank you, thank you, thank you fanny! That was so easy! I can't believe I just fixed my washer in 5 minutes!
Posted on Jun 26, 2008
  • Gregwood111 Jun 25, 2011
    Great advice, worked like a treat!
  • roboverson
    roboverson Oct 03, 2012
    I had nothing behind the pump but I removed the hoses as well and found a penny lodged in there..removed it and it worked perfect! Thanks
I have a Fisher Paykel clothes Washer Model WL42T26KW1. It has quit agitating. It spins, and rinses, but does not agitate. None of the lights are blinking and it is not giving any warning beeps. Can y
Push power button and start button together, push water level up than push start button, turn machine off at wall and unplug it, plug back in and start machine as usual, that may fix the problem, if not, suspect the ECU board is faulty
Nov 22, 2014 | Fisher Washing Machines
IWL16 leaves black specs on clothes
there could be something stuck in the machine between the two bowls. lifting the lid, removing the ring, agitator and inner bowl will easily check this. if the machine has become loud on spin, and the leak is actually from the bottom (more likely) then it could need seals and bearings replaced. don't run it too much more while leaking, electricity and water don't mix XD
Nov 10, 2013 | Fisher Paykel EcoSmart GWL15
**** buildup in top load washer. what to do
Unscrew the agitator and wipe out all accumulated muck. Screw agitator back on, and put through a rinse cycle with white vinegar and bicarbonate soda. This will flush any residual scum. You may have to repeat procedure every 6 months.
Dec 03, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel GWL 15 Rotor Position Sensor
Does It just shake bowl left & right, it will soon give you fault code 56.
Well its a board problem you will need to get technician to fix this board, three resistors(R129,R130,R131) need to be changed for a 1MegOhm resistor.
Jul 08, 2012 | Fisher and Paykel GWL11 Top Load Washer
Hi, I have a WA75T65GW1 7.5kg top load washer. I run a favourites program with cold water cycle, auto level and fast spin. The cycle is getting stuck all the time between rinse and spin cycle, bowl is...
This problem will often occur with a light load of clothes. The beeping is usually the unbalanced load alarm. Often, redistributing the clothes around the agitator and moving the agitator manually up and down and side to side to center it again will fix the problem. You may need to advance a new cycle to where it spins out to empty the washer and run the laundry again.
Jul 30, 2011 | Fisher and Paykel Washing Machines
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
2,356 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
