Question about RCA F32650 32" TV
TV won't come on!
Sunday, the power in my family room went out; so I turned the power back on in the room. When I turned the power back on, the TV came on but it was going through all the channels. I don't have the remote that came with the TV, so I couldn't hit the menu or exit buttons for the channels to stop (it wouldn?t let me use the remote anyway). I unplugged the TV, and plugged it back up. The channels were still turning by itself, so I unplugged the TV for about 15 minutes. I plugged the TV up once again, and it wouldn?t come on and it hasn?t come on since. I?ve checked: ? The outlet ? The TV chord ? I?ve unplugged everything in the room Please tell me what to do.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Posted on Sep 12, 2007
Power surge tv won't turn back on
Check and replace its main power regulator board. Before replacing it, check the fuse, can be located on this board itself.
May 08, 2013 | Panasonic Viera TH-42PX80U Plasma TV
Tv won't turn on
Check for input power in outlet. Try connecting the TV to a different power outlet you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | RCA L22HD31 22 in. LCD HDTV
What amplifier do i need to connect 4 speakers to my vizio P50HDTV10A TV
Check the back of your set there are 2 Audio RCA Jacks, You can't do it with an amplifier alone because that won't split the channels to 4. You have to go to a surround sound receiver.
Jul 14, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
I was watching a DVD and I paused it to turn to TV and I turned it off on TV mode, when I went back to my room the tv was making a low screetching sound so I went to turn it on and it won't, I changed the...
Tries tv unplug,replug it back like an hour later.See,if that solved ur problems.If still have the same problems.The power supply board have the problems the causes,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Sylvania LD195EMX 19 in. TV
Solution to Vibration
you might try to turn it down and maybe move it somewhere else in the room i have the same problem its just my neighbors are in another house across the yard i just have way to much power god forbid some one family or what ever be in my house.
Nov 15, 2009 | Polk Audio PSW10 Subwoofer
I went into the other room and when I came back into the room where the tv is it was off and now I cant turn it on. When I turn the power on the red button turns green a couple times and then then back to...
Can't really tell without a model number or manual or anything but I bet the bulb went out when you were in the other room and needs to be replaced. If it's out of warranty a new bulb will probably run a couple hundred dollars.
Sep 17, 2009 | Televison & Video
RCA D52W136D 52 in. TV/DVD Wont turn on
Does the standby light flash in a set pattern? Some tv have a error code system which pinpoints the fault by flashing the standby light a certain number of times. Other than that my best guess would be a fault on the power supply or a fuse blown internally. Good luck.
Apr 08, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Lightning hit last night tv won't work cable company says it's in the television
Sorry to here about your problem! This is the time of year I used to get tons and tons of sets, stereos ,games, and vcrs in for repair. On your panasonic it seems that maybe the surge took out the tuner portion or the power supply. It sould cost aprox. 200 bucks or so for a new tuner. Im sure your aware that homeowners will cover almost all repair after the deductable. Good Luck
Jun 04, 2006 | Panasonic CT-36G24 36" TV
RCA F32650 32" TV Logo
158 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
