Question about iLO (2 GB) MP3 Player
No volume broken volume control chip
    Problem Solver:
  • 10 Answers
If that is your mp3 im sad to say that the people who made them did make them broken in 1 way or another. i suggest buying an mp3 that isnt plastic lol
Posted on Sep 02, 2009
Sony Bravia 55'inch led volume controls stopped working. Remote or tv button don't adjust volume
Volume is controlled by the main board. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix it yourself. It's easy.
May 10, 2017 | Sony Televison & Video
Factory reset sony mhc-6700
I don't think that will cure the problem. Volume controls these days are done by an IC. If it fails it can cause the volume to go up on one channel and not on the other. If you trace the wiring back from the volume control you will eventually run into the chip. I would have thought that the two channels will go into one chip and not two separate chips for each channel, but it depends on how complex the system is. If you are lucky the PCB will even tell you that the area is tone and volume control.
Feb 27, 2016 | Sony Audio Players & Recorders
Volume goes up and down on its own....
Volume control circuits these days are controlled by an IC (chip) that does all the work. They do go faulty and produce this effect. You can find this chip by following the wires from the volume control, or looking on the circuit board where that is located. There could be other IC's around it, but basically all pathways will lead to the trouble maker IC.
Dec 28, 2015 | Audio Players & Recorders
Pioneer vsx 52
I am trying to work out which has got the high volume.
If it is the Pioneer then it could be the volume control chip that is faulty. These days volume is no longer determined by a control that adjusts the signal level. The signal is passed to a chip and the volume control setting information is also passed to the same chip. If the chip goes faulty then the volume will sometimes go to max, regardless of the volume control setting. This can also apply to the TV sound as well.
If the sound level is high on other functions of the receiver, such as the radio, then it is certain to be the sound volume control IC.
Nov 10, 2017 | Pioneer Elite VSX-52
Automated Volume knob turning up on its own
The control will be driven by a sound control chip. This will be faulty and needs to be replaced.
Jan 03, 2018 | Audio Players & Recorders
I have a Musical Fidelity A1008 integrated amplifier. It has one problem which seems to persist despite 3 attempts to fix it. When I try to tune down the volume, it makes a sudden jump, then it goes down....
The volume control on modern units is done by a chip inside the unit. That determines the volume and sometimes things like the tone. The fact that it is intermittent, probably means it suffers from a heat problem. The only cure will be a new chip. If you can do this yourself then just follow the volume control wires back to the main board.
If you can't it's off to the repair shop with it.
Dec 01, 2017 | Audio Players & Recorders
Something is loose inside, nothing works no on or off no volume nothing
Remote was probably dropped...there is what is called a resonator inside the remote that sets the frequency for the controller chip..it has probably broken off the board and is rolling around inside...if you know how to solder, then you can take remote apart(some have screws, and some are snapped together) and resolder this component back to restore operation. It should be obvious where it goes..but some manuf. may mark the board as X1, Y1 etc..
Jan 06, 2011 | Televison & Video
I have an 17" (2 in1) n Tru Tech LCD TV (with built in DVD player) The volume can not be adjusted, whether I is the remote or volume control on the TV. It goes to#15 and stays at that volume. What Can I...
I assume "#15" is the displayed volume setting on the screen when you try to adjust the volume. Is this the maximum? If so, perhaps the front panel volume up button is stuck on (not the remote control; nothing else on it would work if that were the case).
Another likely cause is the TV's microcontroller chip or memory chip that goes with it has a fault in its volume control address location.
You can check for a stuck button by comparing its feel with the volume down button when you press it. If it is stuck, the difference in action will probably be noticeable. If you can't tell any difference, the set needs internal repair.
Oct 22, 2010 | Televison & Video
The reciever volume will not ajust .. It is fixed at one set volume
Volume controls today are not potentiometers anymore. Manufactures use devices called encoders. When you spin the encoder it sends a binary signal to a decoder chip that will in turn increment or decrement the volume. Either your decoder chip is bad or the encoder itself needs replaced.
Feb 10, 2010 | KLH R3100 Receiver
ALTEC LANSING MULTIMEDIA COMPUTER SPEAKER SYSTEM:
the controller chip inside your altec is possibly defective. i have the acs 45.1 and the unit wont turn on.. the culprit is the main power/volume chip.
Apr 30, 2008 | Audio Players & Recorders
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
