Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
No espresso flows out - just water from the steam nozzle
Oh please help. I am absolutely uncaffeinated and soul-crushed.
The beans grind just fine, and the ground pre-formed pucks dispense into the drawer. But no espresso actually comes out of the espresso dispenser - instead, a lot of hot water flows out of the steam nozzle. All the "espresso making" noises seem to occur without any issues.
Everything was fine until I re-assembled from my latest clean! I've had this machine for four years and have done the cleaning and re-assembly exactly the same, so I don't know what to do. My boyfriend tried to use the machine without me - he didn't know about the little circular filter having to be re-fit, and he had no espresso come out either, nor did he have little pucks - just sludgy grounds in the drawer. I re-fitted it just fine, so I don't know why this problem is persisting.
Please help!
  • jlgerber May 12, 2009
    I am having the same problem. The machine has worked great up to now.
I am sorry I cannot help but I am having the same problem with just getting sludgy grounds - what did you do to solve this problem? Thanks.
Posted on May 06, 2009
Saeco incanto water doesnt cycle
can you hear the unit working and the pump activating in the unit if you can most of the time units get clogs in the nozzle heads if you use a pin or needle to clean out the nozzle head it will restore the water flow so that the water is able to come back out the nozzle. This is mostly due to when people use the finest setting to grind the bean and dont realize that coffee beans contain oil and what happens when you mix oil and water and very small grind it forms clogs in small areas if you are not hearing the pump run then you most likely are not supplying the unit with the proper amount of power to run the pump. If you have any further questions message me back.
Thank you
Rick
Dec 28, 2011 | Saeco Incanto Classic Espresso Machine
Tip
Espresso/coffee not coming out
If you are having a problem with your espresso/coffee machine with water coming out of the nozzle of your espresso/coffee machine or there is a smaller amount of water then usual that you notice coming out of the nozzle area, locate a pin or a sewing needle and clean the nozzle head with the pin or sewing needle. This actually happens due mostly to the grind level of the beans that most people have there unit set on. When you first get your machine there are actually no problems grinding your beans to the finest setting but as time goes on these small grinds end up building up and eventually clogging the nozzle head due to the fineness of the grind and the oil that is found in coffee beans. This also may require more then one cleaning with the pin or sewing needle on the nozzle head depending on how fine the grinds are that you use in your machine. All espresso/coffee machines should have this done often especially if you are used to a finely ground coffee. The simpler solution would be to turn down the grind setting but preferably more people set there unit to the highest grind setting thinking there will be a difference in the taste or strength or robustness of the coffee or espresso. If the beans are not ground at the maximum setting by turning the fineness of the grind down you not only save yourself the amount of time to clean the nozzle head with a pin or needle. You also prevent clogs of this finely ground amount of coffee from backing up in your water path within the unit as well. If the fine grounds are not removed in this manner eventually you can cause damage to the machines water pump as well.
Thanks again
Rick
As you can see from other customers replys this does work very well at alleviating this clog issue in the nozzle head
Click these links
http://www1.fixya.com/support/t10480669-not_come_out
http://www1.fixya.com/support/t10277688-not_getting_thick_plugs_grounds_more
on Sep 24, 2011 | Coffee Makers & Espresso Machines
My Breville coffee maker leaks water from underneath. What would cause this?
There could be a couple reasons why your coffee machine leaks from underneath. To diagnose this issue properly you would need to think about how the unit performed before it started leaking from underneath. Was there not water coming out of the nozzle or spout head which is the part the coffee comes out of before this happend? If there was no flow through the nozzle head this is most of the time due to the fineness level that people grind there coffee at. I see this issue happen very often in both coffee makers and espresso machines as well. Everyone loves a good cup of strong coffee. Some do actually believe and yes I have had it proved to myself as well that when you grind the bean to the finest level that you can or close to it the coffee is made with a bolder or stronger or more aromatic taste and flavor. What many do not realize is coffee also is made up of oils. When the coffee is ground to a fine level the at first everything flows well through the water flow path of the machine and out the nozzle head. No one realizes though the small deposits of oil from the grind being so fine that are left in the flow path due to this grind level. As the machine is used more frequently over some time the oil starts to collect grind particules in the flow path towards the nozzle head until eventually it clogs and blocks the nozzle head where not even water will come out of the nozzle. The way to alleviate this from happening is not only to turn down the grind setting but also if you do descale your machine use a pin or sewing needle on the nozzle head spout hole to clean the head from the build up on the inside of the head. If you were not to clean the head over a period of time eventually it would block coffee or espresso from coming out of your machine totally. When it does this the water pump is still trying to push the water through the path and due to the blockage it cannont so in turn the pump builds up pressure and you eventually either end up with a leaky or bad pump due to this. When you do use this pin method to clean the nozzle head it may take more then one time to clean the head depending on how much use before the last time you or someone performed this. If you have any further questions message me back. Thank you again I await your reply
Rick
Nov 23, 2011 | Breville BKC600XL Coffee Maker
Gaggia Titanium - I had a mesasge come up saying that the Grinder was blocked. I cleaned the doser channel by removing the coffee doser and then the coffee dispenser. I then opened the small spring loaded...
Hello there,
What you need to do is to first prime the machine then you descale it after doing this the machine will work perfectly fine.
To descale the machine, please click on the link below so as to get the manual and know how to descale it as the descale procedures and priming procedures are in it.http://www.espressotec.com/store/pc/catalog/gaggia/ga1150_gaggia_titanium_manual.pdf
Hope this helped.All the bestElect_Comp
Oct 08, 2011 | Gaggia Titanium Espresso Machine
On my Manifica which is about 5 years old I get the message that the ground is too fine and to adjust it when I am trying to froth the milk. I have cleaned it, adjusted it , taken all the beans out and it...
Hi
A grind that is too fine will result in your espresso being too bitter. Rinse between shots because the infuser clogs easily with black espresso muck. Not rinsing will cause the machine to shut down with a message that the "grind is too fine".
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. Try turning the grinding regulator 1 click clockwise and see if that works.If not try inserting the water spout press the ok button and then run water a few seconds.
If you remove the water tank too early while it is making coffee it will display that message as well.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 03, 2011 | DeLonghi Magnifica 3300 Espresso Machine
RE: F9 Upon startup the unit goes thru the normal cycles for making an expresso but, after the beans grind, little to nothiing is dispensed. The unit stops and the message is to fill water portion. I push...
Hi Bill
What happens when you do a tea ? (hot water only, NOT the steam button) do you also get little water ?
The fact that you are getting steam is good as there are 2 heating systems in the unit.
Have you ran the descaling recently (if you do not use filter ) ?
If you have or use a filter the problem is likely to be at the rear of the machine, however the back contents all the power and you will need to be happy to do some stripping down of the machine,
In the back you have the pump, valves, heater etc.
I am just about to draw up a flow chart of the water system inside the machine and have it published online (couple of days).
Are you happy to strip machine down ?
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Jura Capresso Impressa F9 Espresso Machine
Grinding coffee but water not making coffee
Check to make sure the quantity button has not been reprogrammed. To do so, push and hold the coffee button until coffee flows through. Also be sure to check the brew-unit. In some cases if the b-unit is plugged, it will not allow water to flow through. Also check to be sure you are not grinding too fine, if coffee is too fine it too will plug the chamber...........Hope it helps.
Steven,
info@northwestkitchenware.com
Jun 30, 2009 | Saeco Royal Digital Plus Coffee...
Cuisinart 12-cup grinder coffemaker all gummed up
It is endemic to this unit - condensation builds up in the grind chute, which makes the grinds stick to the walls of the chute. Decalcifying with vinegar/water helps, but only in an indirect way - by keeping the inside tubing clean, decalcifying generally allows the water to flow through the machine without obstruction. Inside tubing that has calcium, lime deposits built up obstructs water, and makes it flow through the machine slower - when water flows more slowly through the machine, the machine steams off the water at a higher rate, hence more condensation builds up in the grind chute walls.
Generally, i have found all Cuisinart coffee and espresso makers to be high maintenance to a greater or lesser extent, but the Grind-n-Brews have the highest cleaning/maintenance requirement.
Mar 26, 2009 | Cuisinart Coffee Makers & Espresso...
Water does not get to main compartment
try priming the machine ( find the plastic gizmo that came with the machine for this purprose..can you get water from the steam nozzle?..there is an internal water filter that may become clogged if you aren't keeping the water tank clean.
Dec 14, 2007 | Saeco Vienna SuperAutomatica Coffee...
Everything seems to work but no coffee
take down the machine and change rubber seal for the water reseviour and the nozzle they are brikley.good luck.it also needs a good cleaning there after.
Apr 25, 2007 | Saeco Magic De Luxe Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
138 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
