Question about SanDisk Sansa e200 MP3 Player
E200 problem hi there my sansa e200 is freezing up and will not actcept music downloads. It has given me problems for a while now. the device will say bad track when i try to go to the next song and some times it won't even go to the song listed on the screen. i don't know what to do about this problem. i would like a responce as soon as you can help me with this problem. thanks Mark
  • 626 Answers
Where is the music coming from? If you have lots of Bad Tracks errors, the music is usually encoded incorrectly and the device does not know how to decipher it. If the device still connects to the Computer, try to format it. My Computer, Right click on Device name (e200) and select format. I would also update the firmware. It is available from the SanDisk website. http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Best of Luck.
Posted on Sep 12, 2007
SOURCE:
Won't download music
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Thanks
Feb 15, 2010 | SanDisk Sansa e200 MP3 Player
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
The firmware for my sansa fuze wont download right
hi
Jun 28, 2009 | SanDisk Sansa e200 MP3 Player
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa m200 series and my macbook pro
It is complicate,
it works on Mac OS only if you downgrade firmware for sandisk.
Here is how to do it.
If system crashes while you install the firmware you will damage the sansa, Mac OX is solid , but be careful with the USB cable.
Here is the procedure: How to use your SanDisk Sansa e200 Series .mp3 player with OS X ...
Here you can also download software
Sep 13, 2008 | SanDisk Sansa e200 MP3 Player
Sandisk sansa e200
To get songs off of mine, I went to my computer, and then to Sansa e250R (though your numbers may be different), then to music, and I just deleted what i wanted to get rid of. Im not sure, but this may only work if you're in PlaysForSure mode, which is changed on the mp3 player itself. Also, it leftempty artist folders on my Sansa, and I'm not sure how to get rid of those.
Apr 27, 2008 | SanDisk Sansa e200 MP3 Player
My sansa e200
-Plug in your mp3 player
-Go into 'Limewire', select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files.
-Either select all your songs, open them with 'Windows Media Player' and transfer them that way.
-Or 'Open My Computer' then open 'Sansa e200' and drag the songs from where your songs are located [My Music] to the 'Music' folder in your Sansa e200 folder.
[MyMusic] Song.mp3 >drag to> [MyComputer/Sansa] Music.
Dec 26, 2007 | SanDisk Sansa e200 MP3 Player
Use rhapsody for the trial period and now My SanDisk Sansa e200 won't acknowledge any downloads on my e200 since I didn't sign up for rhapsody. How can I get my e200 to allow download from somewhere other...
If you didnt delete the music from your trial subscription with Rhapsody, they are still on the device, taking up space. Your device will allow any type of music to be transferred, it doesnt have to be specifically from Rhapsody. Best idea is to "format" the device to remove everything and try transferring the music onto the device. Connect the device and go to My Computer>Device Name, then right click on the device and select format. This will erase everything. If you are not able to format the device, change the mode, then try again. Device>Settings>mode or USB Mode. Reply if you have more problems. Best of Luck.
Sep 16, 2007 | SanDisk Sansa e200 MP3 Player
Freezing at "refresh database!
I had the same problem once with my NEW one as well. You have to reinstall the firmware then erase all your music if you can't find any corrupt files on it. to get the new firmware, you must dowload it from somewhere (can't remember exactly) and then start your mp3 in recovery mode (turn "hold" on and hold "record button" until recovery mode shows up and asks you to put files on 16 meg removable disk.) the firmware to be exact. once you have the firmware files, put them on that 16 meg removable disc then disconnect mp3 and it will reset. it shouldn't want to refresh database. at that point you should delete all your music and start from scratch. I know it sucks!:(
Jan 27, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
80 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
