Question about Pinnacle PCTV 110i (210100458) Video Capture
A big blue Exclamtion Mark replaces the picture in Veiwing window.
It only happened after bringing in another project to the one I was working on. I put the new small project on the time line & up until this point every thing was ok, but then I then split out a scene of the newly introduced project and moved it along the time line. All the previous frames to the newly dropped frame, still showed the picture but when played only the Exclamation Mark in the viewer window would be showen along with any titles but without sound.
2 Suggested Answers
  • 19396 Answers
SOURCE: Had to install new motherboard
The problem is not the Microsoft certification. The certification request is prompted only before installation. Its only effect is allowing or denying the drivers installation.
Pinnacle website has two different driver versions. Try both versions. If that does not work there is usually a conflict in allocation of system resources.
Here the links.
03/22/2005 -
Posted on Jan 18, 2011
  • 670 Answers
SOURCE: I am having a problem
What hardware are you using to capture videos?
Have you checked the hardware if it's working properly. Have you tried lowering some settings for the pinnacle studio as the GPU of your video card could be going bad and it's not able to keep up with the settings that you have for the software.
Hope this helps!
Posted on Aug 31, 2011
0 characters
1 Points
I'm trying to capture video from a Sony Mini Digital Handy Cam, onto my Toshiba Satellite laptop (Windows Vista). I'm able to capture the audio from the mini tapes within ArcSoft and E-Z Grabber,...
this might be a problem with the driver
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamtion ? ! mark or a red X a new driver will need to be installed right cick select reinstall/update driver if your computer came with a motherboard disk the drivers could be on it or you might need to download one
if this package is not the right
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
also this link will provide you with many freeware and share drivers
hope this helps you
Aug 15, 2011 | Diamond Multimedia ( VC500) Video Capture
Hi sir, I need help on my pc, i install a usb 2.0 pci to usb card on the mother board but cant get it working, i have on device manager under other devices have an exclamation mark on universal serial...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
Jul 30, 2011 | NEC TV Accessories
Video capture with this device is great, but I really don't care to relive the silent movie era with just background music. I want the sound and dialogue that should come through. This not happening. ...
Here are couple websites with drivers: one , two. Choose device familiar with yours download and install latest drivers - your device must be unplugged. After installation you'll be prompted to restart Windows, after restart plug your device and check if it is installed in Device Manager properly. If any of devices has yellow exclamation mark, try to manually update the driver and choose - Let me choose the driver to install the correct driver should appear in the menu. After drivers are installed you have to properly connect wires and configure format PAL or NTSC, resolution and so on. Good luck! And by the way there is no good driver for Windows 7 x64 it can be installed but Blue screens from time to time.
Feb 02, 2011 | Sabrent USB-AVCPT Video Capture
Avid Express Pro vers5.
Can you set up an external monitor (like a client monitor) and change the setting to view through external monitor it is worth checking if this works, (even if you can't) it is worth changing this setting and then change it back. I have had issues with lagging picture wile capturing in the past and swaping the input from SDI to Composite and back again has worked for me. If your graphics card seems to be still working with other software packages I doupt it is this but reinstalling avid could clear up issues (just back up what you've re-captured).
Jun 02, 2009 | Avid Xpress Pro - (bundle) (05600360101)...
Matrox rt.x 100 / adobe premier 1.5
There are Thousands of Problems associated with Vista right Now. I just got word this week that a New Windows Version is Coming out to Replace Vista Because of all of the Problems Everyone is having with Vista. Keep the Stuff you have right Now as It very well may be Compatible with the New Version Coming out Very Soon.
Jan 24, 2009 | Matrox RT.X 100 (RT.X100) Video Capture
Hvr1600 scheduler problem.
Scheduler window is cut off or to big to click on the Save or Cancel buttons? Please double check that your system display DPI settings are not over 96. Open the display properties of your system under control panel. Click on the settings tab and then advance. Look for DPI settings; make sure it's not over ninety-six. If it's over that bring it back to 96 and restart your computer.
Nov 27, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Shift question mark not working
Keyboards can go bad - luckilly they are cheap. It may be time to replace it.
Jul 18, 2008 | TV Accessories
HP Digital/Analog TV Tuner color problems
go to to down load media center drivers to run the hp expresscard tv turner in windows media center works with xp and vista
Feb 03, 2008 | HP Expresscard TV Tuner For Windows Vista...
Pinnacle PCTV 110i (210100458) Video Capture Logo
952 people viewed this question
Top Pinnacle TV Accessories Experts
Brian Sullivan
Brian Sullivan
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Pinnacle TV Accessory Expert? Answer questions, earn points and help others
