Look in your Device Manager and make sure the correct driver for audio hardware is loaded. Make sure the is no hardwareswitch on your laptop that is switched off.
try download skype and see if you can see your self first, if not try down load new version of software or un-installed the drive and restart your PC. at pc start up it will auto install the new driver
to activate the wifi switch it is i believe it is down of the left front of the laptop actually on the front of the laptop itself and normally a slide switch which needs to be pushed over to the right before it will activate
loud speaker icon depending on which operating system your running
if you are on windows 7 look over to the bottom right handof your screen if you cant see the audio
icon that looks like a loud speaker
can you see a upward facing arror
if so click on that arrow then click customize then go find the volume icon and click show icon
and notification
if on xp try this
start
settings/control panel
audio/sound
somewhere in there you should be able to tell it to show in taskbar
If you haven't change any of the security parameters on the laptop, the default is a 30 minute wait before it resets/unlocks the account. If that doesnt work you can use a program called WINTernals that will allow you to change/reset the password.
Firs of all I like to remind you the model that you have doesn't come with integrated microphone. However It will work any standard PC microphone that you can obtain around few dollars or less from IT stores. All you need to plug the microphone to the right side second socket socket as illustrated below
If issue persist please post further I will provide assistance accordingly
To use the external vga connector of a laptop, you have to activate it. In many notebooks it is Funtion and F7 (Fn-F7). In your notebook it may be F5 or F6, look for a monitor sigh in the F keys.
The activation may sometimes rotate in sequence , ie, External + LCD, LCD, External... and so on.
