Question about RCA Single DVD Player
DVD Door won't close
Hi there. I just begain having a problem with my DVD player. The door wouldn't open at first and now it won't close. It closes a little bit and then sounds like it stuck, it won't even close with the power off and putting pressure on it. Someone please help me!!! It tis an RCA DVD Player.
  • Anonymous Nov 06, 2007
    I have a 5 tray RCA home theatre that won't open. You can hear whirring like it is trying to open, but it doesn't. Note to me to not buy models that cannot be found on the RCA website. This played maybe 15 dvds before this problem was encountered.
  • 752 Answers
It needs to be realligned. There is a little peg (usually white) that rides in a slot under the tray. It has popped out and needs to be put back in the track.
Posted on Sep 12, 2007
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Portable DVD player won't recognize door is closed.
My guess would be that the switch inside that the tray hits to tell the dvd player it's closed is broken.
Aug 23, 2012 | Philips portable dvd player phillips...
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
Door won't open
What you need to do is to prepare philip screw and oil.
1.) open the back cover of your dvd by unscrewing it.
2.) look for the center area specially on the door.
3.) put an oil where the door close and open.
You can also put oil to all moving parts for much better result.
4.) then try to test it if it works,
hope it helps you and rate me if it does.thank you..
Nov 25, 2011 | Televison & Video
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
Dvd slider door won't close.
Hi, is it fully open, or just partially open?
Is it nearly shut but just jammed? If so have you tried inserting a flat peice of plastic and pulling the draw open. You could do this with no power to the dvd player, It might be that you haven't inserted the disc properly and it is wedged in.
Try all this and see how you get on.
Regards - Anthony
Feb 14, 2010 | Memorex Televison & Video
My DVD Player does not reject a DVD. It gets stuck.
I had been closing the door at the DVD slot manually. I found that if I closed the DVD door with the close button, and then opened it with the open button, it no longer got stuck.
Jul 04, 2008 | Philips Televison & Video
Durabrand pdv-702
changes are good that there is a disc stuck in the dvd player
Aug 24, 2007 | Durabrand PDV-705 Portable DVD Player
Televison & Video Logo
293 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
