Frigadaire front load rubber smell and won't spin
  • 490 Answers
Just by what you are telling me it sounds like it either locked up a transmission or the belt needs to be changed
Posted on Apr 13, 2009
How do you take off the front panel of lat2301aae. I think the belt may be bad.
I would be looking at the drive belt under the machine as that will be the only place to produce a rubber smell. If it is loose and by now destroyed you may have to replace it and adjust the tension.
Jul 05, 2014 | GE Profile WPRE6150KWT Colossal Capacity...
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
My machine is a maytag LAT2300AAE on spin cycle it will not spin and makes a noise and can smell burnt rubber what is wrong? Also how do you open it to check it out? thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 14, 2010 | Washing Machines
The washer makes a loud noise when it spins and there is a burning smell.
sounds like bearing may be going out shut down call repairman if the smell,smells like rubber its the belt
Nov 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I am trying to replace a vibration shock absorber on our frigadaire front loading washer. the nylon bolt just keeps spinning and spinning. Any ideas?
yep,,, its striped its thread, get some moll grips on it and butcher it out? you will then need a new bolt,,,
darn silly idear them nylon bolts best thing for this bolt if melt it down and make stocking out of it?
Oct 23, 2009 | Frigidaire GLWS1233A Top Load Washer
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Frigadaire front load washer, drum is very low in
Is the drum bouncing around?
Remove the front lower panel and the top from the cabinet. Replace the shocks and/or tub support springs if they are broken.
If the spin is noisy, there might be a problem with the inner basket or the tub bearing.
Mar 05, 2009 | Frigidaire Washing Machines
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
