Question about HP Combo Case HP PAVILION Speakers, Mouse, HP Keyboard, Floppy (B09110)
RAIDMAX X1 Computer Case
I have a abit motherboard KN9 SLI and I can not find the way to connect the sound cables from the case to the motherboard. Speaker port on motherboard it's different from case cables. Do you know how? Thanks Mario
  • Mario Mira Sep 13, 2007
    Thank you very much, but I had a port on the motherboard that refers to HD SOund and one configuration to the onboard sound CA97 or something like that so I just followed the connections of those pins and so far it seems like it's working fine.
    Novelist:
  • 231 Answers
Hi, if this is only the case speaker cable you are asking about, then just use a small pair of side cutters and cut the plug apart and plug the red and black cable on seperately. Regards mistyman
Posted on Sep 13, 2007
SOURCE:
This is going to sound vague, but currently a friend and I are working to get this desktop PC working that has a KN9 SLI motherboard installed on it. Currently, the issue is: The computer turns on, a red...
Try checking the jumpers on the motherboard. A lot of the SLI compatible boards have jumpers that need to be configured properly. You can find out the positions by checking the motherboard manual. Are you using an SLI capable video card or is the video onboard? I just ask because I had the same problem once while trying to install an SLI video card. I had no picture on the monitor and I couldn't figure it out for the longest. Finally I found the answer in the motherboard manual and it turned out to be a jumper that was set wrong. Hope this helps.
Mar 23, 2011 | Abit KN9 SLi Motherboard
No video, Abit KN 9 Ultra Intermittant long beep, can't answer for beep code anyone know?
A long beep signals that no memory is detected ; test the memory sticks and reseat them.
Dec 02, 2010 | Abit KN9-SLI Motherboard
Abit kn9 sli, my problem is this, when i turn my pc on the fans spin for about one second then it all turns off. the power lights on the motherboard stay on but it wont power up at all. if i turn the power...
Are you sure the 4 pin connector is going in correctly? Some motherboards have an 8 pin socket, and the connector can be placed in improperly. The symptoms you describe indicate a dead short on the power line when plugged in.
Jun 20, 2010 | Abit KN9-SLI Motherboard
I don't have any sound and I have downloaded the drivers from realtek. I recently re-formatted my hard drive and that is the only problem I'm having
Try downloading drivers for your motherboard, there may be an audio patch or some other driver you are missing
Oct 12, 2009 | Abit KN9-SLI Motherboard
Abit kn9 sli overheating ??
The problem could be a failed electronic component, and no cooling remedy will solve the problem. When some components fail, they result in high heat conditions.
Aug 01, 2009 | Abit KN9-SLI Motherboard
I just received a hand me down system with the abit kn9-sli motherboard. After installing a new amd 64x am2 6000+ processor and a new hard drive...when I powered on the system...the systemboard speaker...
Usually the sound is called bios beeps. They let you know in advance if there is a problem.
Usually a high low bios signal ( like an old german siren) means a cpu issue.
Check the processor and cooling fans, and check it's temp....take two aspirins and call me in the morning...LOL :)
Hank
Jul 30, 2009 | Abit KN9-SLI Motherboard
Video Card Upgrade Id like to know if the nvidia 9500 video cards are compatible with the Abit KN9 SLI boards. I currently have the 7800 GT style video cards. So I am a couple of years behind the curve. I...
I would not bother with the 9500 series they are just OC verisons of the previous ones, and everything above the 9500 (9600, 9700, 9800 et al) are too close in price to the latest generation, not cost effective. Take a look at this link, I believe it will satisfy your needs.
http://www.ewiz.com/detail.php?p=MSI-250_51&c=pw
Jul 08, 2009 | Abit KN9 Motherboard
Power Up
So after 5 seconds it won't come on again at all, or it runs for 5 seconds each time? What else do you have running on this computer? I'd suggest disconnecting all non-essential devices (hard drives, all but one memory chip, any expansion cards other than video) - if one of them has a short, they can pull down the power supply (regardless of the condition) and cause it to shut off exactly as you've explained. Let me know if that makes a difference (it obviously won't boot without a hard drive, but it will get far enough to see if that's the problem). If that doesn't make a difference, let me know and we'll try something else.
Sep 01, 2007 | Abit KN9-SLI Motherboard
Computers & Internet Logo
78 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
