Question about Whirlpool LEQ8611L Electric Dryer
Dryer won't heat and the back panel won't come off to look at problem.
    President:
  • 331 Answers
ML,
Access to the heating element is through the panel below the door. Between the lower panel and door are 2 clips. They're about 3" in from either side. Use a putty knife or a flat screwdriver to depress these clips while simultaneously pulling out on the lower panel. When both sides are loose, rotate the panel forward then lift it off of the lower retaining clips.
UNPLUG THE FRYER BEFORE PROCEEDING ANY FURTHER!!!!!!!
You'll see the blower on the far left. Just to the right of that and mounted on top of the blower housing is a small white thermal fuse. Just to the right of that is an operating/cycling thermostat. Remove the wires from the thermal fuse and test it with a meter. It should read "closed". That is, electricity should flow through it. This is the first thing to check... they fail often.
On the right side of the cabinet, you'll see the heater assy. The large red wires feed the element, remove them to test. You'll also see 2 more thermostats mounted on the heater can, these should be tested, too.
All of the components I mentioned should show electrically "closed". If anything other than that, then that is the failed component.
Write back if you have further questions, and don't forget to RATE this as "FixYa"! Thanks, again.
SG
Posted on Apr 13, 2009
  • 490 Answers
You have to take the front of the dryer off to look inside
Kenmore elite he4 moder 110 won't heat
In terms of likelihood, here is what's wrong:
1) The heating element has failed.
2) One of the several "overheat thermostats" has overheated and failed.
These are found in the back or the bottom of the dryer in the rear.
3) One of the wires to something, like the heating element, has burned in two.
4) The panel where the electric cord attached to the back of the dryer has failed. This will be inside the back of the dryer, usually behind a small plate.
5) The circuit breaker for the "heating" circuit wire of your dryer is popped and needs to be reset. (That is the circuit breaker found in your hall, or basement, or garage, or wherever.)
If you decide to fix it yourself, a question to "fixya" might get you step-by-step instructions.
Be blessed
4)
Feb 11, 2013 | Dryers
Whirlpool supreme LER7646EQ2 won't heat up
The heating element is no good. They break after years of use as they heat up and cool down over and over, they wear out. The part is cheap and yes it is easy to replace. Turn your dryer around, and take off the screws to a short piece of metal that has "vents" in it. It should be sticking out a bit compared to the rest of the dryer back. normally 2 or 4 screws holding it there. You'll see the element. Just pull it out, take it to the appliance shop or Sears and get another element. Go home, stick it back in there and reconnect the panel you took off. Cheap part, simple fix...you'll be surprised how well it heats after that.
Jun 09, 2012 | Whirlpool LER5636P Electric Dryer
My dryer won't heat up
You can try the heating elements. First unplug the dryer and you will have to take back panel off. You need a Volt Ohm meter to do a resistance measurement. Place the leading one each end of the elements and the reading should be close to "0". I'm thinking if the dryer is old the heating elements has burned out.
May 17, 2012 | Kenmore Dryers
Kenmore 80 series dryer won't start.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch this part testing video.
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 21, 2011 | Dryers
Bosch nexxt 500 series electric dryer will not heat up, it just blows cold air. I have removed the back panel and pressed the reset button-nothing changed it still won't heat. The dryer had been in...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 16, 2011 | Bosch Dryers
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
Whirlpool LEQ8611L Electric Dryer Logo
216 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
