Question about Garmin Nuvi 660 GPS Receiver
Change map setting
How do i change my map from europe to usa - then setting does not have the option of usa map
  • 385 Answers
Buy the package first from Garmin.com
SD card, download, disc, which ever.
in your Menu, touch maps, map info, tick the box when loaded on the device.
You may need unit I.D. to activate it,
it's in your tools-system-about menu
and serial number on the bottom of device.
I hope this helps
Regards.
Posted on Apr 16, 2009
How do I convert my sat nav from europe to usa
Some Sat Navs can't convert, If it's bought & set to UK & Ireland maps, then you are stuck. 2nd thing , even if you can use Europe Maps on your Sat Nav, you still will be unable, to load USA maps.
Sat Nav not compatable, You will have to buy a NEW ONE.
Mar 07, 2015 | Garmin nuvi 255W GPS Receiver
I purchased a Garmin Nuvi 1350 in the states and I am in Germany and it does not have any maps here for Europe
If you purchased it in the USA, it will have USA maps. If you purchase a Garmin GPS in Europe, it will have European maps. You will need to purchase additional maps for your USA unit to use it in Europe. Go to the garmin.com website and you can purchase the maps there.
Sep 13, 2011 | Garmin GPS
I need to put a scotland map on my garmin.what do I do ?
The map of Scotland comes with the "UK and Ireland", "Western Europe" or "Europe" maps so if you buy any of the three you'll have the map of Scotland. You can buy one of the maps by going to www.garmin.com and logging into myGarmin. Click on the myMaps tab at the top of the screen and then on "Purchase more maps" Follow the prompts.
Before buying the map, if you have a satnav bought in the USA you need to check if it will work in Europe. Most of the USA garmin nuvis will not work in Europe with the exception of those that come with both European and American maps.
Jun 14, 2011 | Garmin GPS
I am traveling ion europe and have purchased a set of european maps for my nuvi 1300. i need to transfer the maps from the sd card to the nuvi 1300
If you bought your satnav in the USA don't transfer the maps to your satnav. The USA version of the satnav won't work in Europe. If you bought the satnav in Europe you should only have to plug the SD card into the satnav for it to work.
Jun 06, 2011 | Garmin nuvi 1300 Car GPS Receiver
How often should you update or is it more practicle to just purchase a new garmin every couple years?
If you're happy with the satnav you have it's cheaper to update. You have the option of buying a once off map update or a lifetime update. That is for the lifetime of the satnav not your life. With a lifetime update, which costs around 120 euros, you get 4 updates each year. This is the cheapest option. However the only problem with this method is that the maps get bigger each time you update and the space on your satnav stays the same. I started off with a full map of Europe and now I'm only able to store Western Europe on my garmin nuvi 760. You can use memory cards to hold some of the map but older garmin satnavs have a problem recognising the maps on memory cards. If you need the full map you might be better buying a new satnav every few years. If you only use part of the map a lifetime update might be the best option.
If you decide to go for a new satnav I would suggest that you go for one with the biggest storage space possible and then get a lifetime update or get a model that comes with lifetime updates like the 3790LMT. You can judge the storage size by the amount of maps it comes with. The 3790 model has the complete USA + Canada and Mexico or the 2370LT comes with maps of Europe and USA, lifetime traffic updates but not lifetime maps.
Apr 24, 2011 | Garmin nuvi 350 GPS Receiver
Can the garmin 72 gps bought in usa be used in europe and are
GPSs can be used anywhere in the world with the correct maps for you particular area installed. They use the same satellites.
Oct 30, 2009 | Garmin GPS
Europe maps microSD card problems
You didn't mention where you live. If you live in the US and you have the SD card with the Europe maps plugged in, it's going to grab the Europe map first. Try going into set-up by clicking on the wrench symbol, then the maps symbol and then "map info". You should see your original map and the europe map. uncheck the europe map to get back your original map. This screen allows you to toggle between both maps.
- Jim
SHARCNET-USA
Dec 09, 2008 | GPS
Changing maps already installed
Hi, Answers to your 2 questions 1 and 2 . ...... 1/ go into PREFERENCES , hit right arow key till you see MANAGE MAPS , Tap that MAP icon and in there will be all the maps you have on the SD card. Select the map you require by tapping the screen. ............................................. 2/ YES , backup the SD card to your PC first. ( you should save everything on the card as it is ) Then delete the Europe map off the SD card and replace it with the USA map . You will need the authorisation code for the USA map in order to activate it. When you return you can swap the maps back again.
Mar 15, 2008 | Tomtom One Europe v2 GPS Receiver
Zumo 550
You'll have to select the europe map and deselect the usa map. Also you might have to change the locales. to do the first thing
tap wrench/tap map/tap about there you should see both maps, select the one you need and return to the wrench menu, select locales slect change all and walk through the menus (especialy the country!!!)
Aug 18, 2007 | Garmin zumo 550 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
457 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
