Question about Kenwood KSC-WA82RC Car Subwoofer
Where do you buy the 10 pin connector
Need a 10 pin connector for my kenwood sub anyone know where i can get one?
I used a computer power cable (the one that plugs into your IDE HDD) and soldered the male end onto the circuit board. Sorted :)
Posted on Jul 28, 2009
    Sergeant:
  • 241 Answers
Go to www.Frys.com They have a huge selection of connectors!!
Posted on Apr 13, 2009
Looking for replacement connectors for the satellite speakers
count the number of pins of your connector so that you will know what to buy, better yet just bring the actual connector to your nearest electronic shop
Nov 08, 2015 | Audio Players & Recorders
CANT SEEM TO LOCATE WIRING COLOR CODES FOR MY KENWOOD KAC-210D CAR POWER AMPLIFIER
10 pins connector black..................GRN yellow.................BATTERY Blue....................IGNITION OR ANTENNA PWR FRON RADIO 4 pins connector purple..................REAR R (+) purple/black ........REAR R (-) green...................REAR L (+) Audio in................RCA jacks
green/black..........REAR L(-)
Feb 26, 2011 | Kenwood Car Audio & Video
I have forgotten bios password of my pc (Toshiba
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration. But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port. Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :- 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Feb 18, 2010 | Computers & Internet
I have a 300 watt rms kenwood 10inch sub, dont know the model at the moment, i was driving last weekend, cold outside, had it turned up to much and i blew it, the cone is frozen and i think the voice coil...
Im sure that there are repair stores that will fix things like that for you...but the fix is fairly easy if you are familiar with using electrical connectors..or even soldering. You should be able to turn your subwoofer over and locate the to "copper" colored wires that run to the cone. If its what you make it sound like then one of them will be broke...you can either solder that wire back together...or you can connect wire connectors to each end of the broken wire and then re-connect it. Some of the connectors slide together and some of the connectors look like small skinny tubes...it depends on how much clearance you have to work with and how handy you are. Again...this is not a professional fix but it will work and should last for as long as you have the sub...just make sure that when you connect the connectors to the wire that they are tight connections and the connector does not slide off..give a small tug maybe. Perhaps you may know a friend with a little electrical experience that could help you. Also if you get this far and it is now working I suggest that you put some electrical tape around the connector because the connector may have the tendency to bounce off the cone of the subwoofer now at high levels of bass. Facing the connector at the bottom when remounting the sub would be a good idea as well but not necessary as it may not look right with the writing on the front of the subs matching when looking at them. If this sounds like something that you cannot do...then your best bet is to take it or call somewhere like a best buy and ask them if they do it or can recommend somewhere that does it..it could be pricey or they could just tell you its best to junk it...but ive done the fix myself and its worth doing it to get the extra life out of the sub...
Dec 13, 2009 | Kenwood Car Audio & Video
I just received this kenwood 100 watt powered sub w/10'' sub from a friend... he says it just won't turn on, i checked the fuses and they seem ok to me just won't turn on like he said... can someone help...
check the transformer has ac around 50 vac. then check the dc power supply at +_ 45 vdc if all that is ok,check the output ic has +- 45 vdc at 2 of the pins,if it does,the output ic is probably no good
Jul 17, 2009 | Kenwood Audio Players & Recorders
Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Jun 24, 2009 | Bose Acoustimass 10 III System
Remote control cable
Within the same manual, you'll find a section that may say: Additional Accessories.
The cable should be listed as an accessory item to order.
Contact Kenwood and ask them how to order the cable.
Oct 22, 2008 | Radio Communications
Wiring a Kenwood KSC-WD250 Subwoofer
7e83231.jpgi had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Nov 27, 2007 | Kenwood KSC-WD250 Car Subwoofer
10 pin plug wiring configuration
7e83231.jpgI had the same problem.  Here is the picture I used.
Oct 05, 2007 | Kenwood KSC-WA82RC Car Subwoofer
Connector Pin Out
Apr 05, 2007 | Kenwood KSC-WA100 Car Subwoofer
Kenwood KSC-WA82RC Car Subwoofer Logo
870 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
