Question about iLO (2 GB) MP3 Player
Ilo mp3 player s/n 0770100321415 1gb with sd card slot
It turns on and says "ilo" but it does nothing. the back light come on and goes of about every 7seconds
  • someone_12 Jan 07, 2008
    did u figure out how to fix it cause i am having the same problem
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
SOURCE:
I just bought sd card for my ilo but when I try to access it wont let me store any music. How do I format it and prep it for access?
You need to format all new cards. Does your Mp3 player show up as a drive when you hook it up to your computer if so open that drive right click on format use FAT32 for windows os. If your Mp3 player does not show up as a drive use the SD slot on your computer to format. Choose the SD card slot drive right click on the drive choose farmat... use FAT32 for windows os. and you should be off and downloading great tunes... Good luck hope that helped.
Oct 06, 2009 | iLO (2 GB) MP3 Player
Compatibility of sd and sdhc
no this device is SD and MMC only
http://www.amazon.com/iLo-Player-Cherry-MP-556-MP556/dp/B0018ZA2V8
Check your spec, sorry
Regards
Richard.
Apr 01, 2009 | iLO MP3 Player
Copying music to the SD card
Plug card directly into PC - your computer MUST have a slot for doing so
May 13, 2008 | iLO (2 GB) MP3 Player
2GB SD Card Problem.
you cant expect all mp3 players to play as many songs as u wnt. each mp3 player has a limit of memory card that needs to be attached. see whats the maximum memory your mp3 player can support. and also see if you can locate all the songs when the SD card is connected to your computer
Jan 29, 2008 | iLO MP3 Player
Not recognizing music on SD card
Not sure if you have found the solution to your mp3/SD-card problem, it has been almost a month. Obviously I had the same problem. That's how I found your question. What I did was re-format both the mp3 and SD, then loaded the SD card first and sofar so good.
Jan 10, 2008 | iLO (2 GB) MP3 Player
Adding a 1gb memory disk
open the battery door and insert the sd card into the slot provided
Dec 29, 2007 | iLO (2 GB) MP3 Player
I bougth a 4GB SDHC card for my 1 GB ilo w/expansion slot, will it work
my new ilo 1gb mp3 player's manual reads: you can use up to a 1 gb sd or mmc card. hope this helps. :)
Nov 30, 2007 | iLO MP3 Player
Adding SD card to my ILO
What, you actually hotwired a flash card into the Ilo? Impressive. Or are you trying to get the Ilo to play music from an SD card, when you have both plugged into the computer? If you're talking about the first, then I'd say you did a good job at NOT destroying your Ilo. If its the second, then unplug your Ilo, put your headphones into the headphones jack in the computer, and play the music from your computer.
Aug 22, 2007 | iLO (2 GB) MP3 Player
Memory expansion slot
If the SD card is a compatible type, it should just read it
May 10, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Rick
Rick
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
