Question about Garden
Pressure washer needs oil what oil should i buy
  • 195 Answers
If it is for the engine regular 10w 30 0r 10w 40.
The pump 10w 30 pump oil.[specify pump oil ]
Find both at any auto store.
Thanks Linda1963 and please vote me a Fix Ya. Ask for jj505
jj505
Posted on Apr 14, 2009
What is oil type for my pressure washer pump (K2300G)?
PDF]Service Handbook High-Pressure Washer Pump 3.532-629.0
www.mymowerparts.com/...Pressure-Washer.../Karcher-Pressure-Washer...
Sep 28, 2001 - For Karcher Pressure Washer Parts Call 606-678-9623 or 606-561-4983 .... Oil Bath. The swash plate and pistons are bathed in oil. (oil type ...
Oct 21, 2015 | Garden
I bought a Simpson 3000 psi gas pressure washer. When I changed the oil (first time) I found the oil does not drain out into the pan but spills over the right wheel. I called a Honda dealership and
Easiest thing to do is buy a pipe nipple of appropriate thread size, a female thread elbow the same thread size and a male threaded plug to match the coupling. Turn the pressure washer onto its side with the drain plug pointing up. Remove the drain plug the screw in the pipe nipple where the drain plug was. Thread on elbow to other end of the pipe nipple and then screw in plug to the open end of the elbow. Buy a nipple that gets you just past the frame of the pressure washer and point the elbow at any downward angle you need to avoid draining onto the wheel.
Jul 22, 2014 | Simpson Garden
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
What type of oil should be used to lubricate the pump
any antifoaming oil but alot of people use multigrade their oil goes creamy as if its full of water but it is just oil that is foam and the air in it takes forever to to come out there are a number of anti foaming oils available use one of those
Aug 04, 2009 | Electric Kranzle Professional 1600 PSI...
Oil used for Cat Pump on pressure washer?
It will be a 30 wt non detergent oil probably. You could contact a Rental store in your area they will have what you need. Hope this helps. 2rns4u <*{{{>(
Jul 22, 2009 | Honda Pressure Washer PSI 3000
What gas and oil do I use on the Honda Excell 2600 pressure washr
That engine requires a separate gas and oil. There is an oil sump with oil level needle and cap on the side of the engine. This is where you fill it with special pressure washer pump oil available from any good outdoor store or place where pressure washers are sold. As for gas, Unleaded or Premium unleaded gas will work fine. Try not to use any fuel with ethanol blends however. Here is a list of oils that will give you an idea what to buy for the oil reservoir: http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2Fs%3Fie%3DUTF8%26ref%255F%3Dnb%255Fss%255Fgw%26field-keywords%3Dpressure%2520washer%2520pump%2520oil%26url%3Dsearch-alias%253Daps&tag=onlinetoolrev-20&linkCode=ur2&camp=1789&creative=390957
Jun 14, 2009 | Honda Pressure Washer PSI 3000
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
PRESSURE WASHER OIL
non-detergent oil
May 11, 2009 | Garden
Garden Logo
304 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
