Question about Sony KDS-R60XBR1 60" Projection HDTV
KDS-R60XBR1 60" SXRD HDTV
Same problem as reported. Green power light goes red, blinks in a sequence of 4, screen blank. Set is 15 months old. Power off/on reset does not help.
  • tenpackb Nov 18, 2007
    19 months old with the same problem. This will be it's second service call in 6 month, the first was the optical engine/block.
  • rae1973 Nov 27, 2007
    TV comes on for 1 second, screen goes black, standby light flashes 4 X in sequence. I never know if the set will turn on and the problem has become progressively worse.
I had the same problem if it is blinking 4 times like I think it is... it is a problem with one of the fans (there are 4) in your TV.. It is a simple fix... try using an air canister to clean them. It will require some disassembly though.
Posted on Oct 03, 2007
SOURCE:
What do i do if my sony sxrd power light starts blinking red
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly
Jun 17, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
My screen is black and sound is off. The green
I have the same problem. Can a bad lamp cause the sound to go out?
Jun 24, 2010 | Sony KDS-55A2020 55" Television
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony sxrd 60 in, won't power up--blinking red light 5 times
You need to replace your bulb. Order a replacement online---it's easy to swap and the instructions are in your manual. If you purchase one from a local dealer you will pay over $150 more!!!
Feb 25, 2009 | Sony KDS-R50XBR1 50" HDTV
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KDS-R60XBR1 60" Projection HDTV Logo
854 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
