SOURCE: phaser 8550, scratch lines through printout
On the display. Call 1-800-835-6100. Xerox will send a tech out free of charge to replace the led display. Its a known problem.
SOURCE: XEROX PHASER 8550
How do you only print black, I have only black cartiages left, but it still asks for the other colours.
SOURCE: Printing Black & White
sure..but you need to set that in the settings of the documents printing under default(use greyscale).
Try this link for more Printer Resources
SOURCE: Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
SOURCE: Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
