56" RCA HDTV Projection Model # R56WH78
I would like to purchase this tv. Does this tv have picture tubes or bulbs? Are you aware of any problems with this tv?
  • 1 more comment
  • Anonymous Nov 27, 2007
    SOMETIMES IT TURNS OFF BY IT SELF, I HAVE TO DISCONECT IT FROM THE AC OUTLET AND AFTER 3 MINUTES I CAN TURN IT ON AGAIN, IT HAPPENS ALMOS EVERYDAY AT DIFERENT TIMES, I PURCHASED THIS UNIT NOV 22-07...
    PLEASE CAN YOU TELL ME ANYTHING ABOUT THIS PROBLEM
    Thank you...Mr. Rodriguez
    [email protected]
  • PFloydNVa Mar 11, 2008
    Considering you posted this back in 09/07, I'm not sure if this will be of any help to you now; other than to limit the number of holes you might put in your walls :). Nonetheless, I thought you might want to know of an issue I've recently come across. In particular, some vendors; particularly Xbox 360; is updating their System Software for Auto Detection. Wherein as, their forcing the Native Mode of the connected device when their devices are connected through HDMI to DVI or any other conversion. After beating my head on a wall for over a month and spending over $300 for cables, adapters and switches, I finally found the route of the issue myself through Internet searches. Even though I've spoken to RCA/Thompson once concerning the original issue, I'm currently waiting for a response to what I have since discovered. Bottom line is, this particular TV has a Native Mode of 480 resolution. I'm not holding my breath, but I'm hoping RCA/Thompson has some way to access the TV's software menu and has the ability to change this setting.
  • Anonymous Sep 25, 2008
    All of a sudden the TV looks like it's in crappy 3D with a rainbow spectrum all around the pictures.
    New Friend:
Why do i have red and blue lines across the top of the tv
Posted on Jun 04, 2010
Yes on the Fly back transformer solder all the pins , this can take care of about 90 present of the problems on the model.
Posted on Feb 13, 2008
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
This is a rear projection CRT TV (picture tubes)Not service-friendly (disassembly,getting parts)more problems compared to other brands....
Posted on Sep 12, 2007
SOURCE:
NEED PART NUMBER FOR PROJECTION HDTV. MODEL R56WH78 FOR THE PROJECTION BULB
Good Morning
your set does not have a bulb it has three CRT'S picture tubes . and if the set is not working its not likely that the crt's have all failed . you most likely have a circuit failure like a high voltage trippler block or some where else in the set . what are the symptoms at start up .
Oct 15, 2014 | RCA Televison & Video
My rca 52inch rear projection tv would shut off then come back on know it won,t come at all is it possable it is a bulb help wayne
this model does not use a bulb, but has 3 picture tubes. Most common problem for this is bad solder connections under the high voltage transformer.
Nov 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replacement bulb
model indicated here does not use a bulb or lamp, it has three picture tubes.
Apr 27, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
We have a 56" RCS
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,have tv pictures colors shadows or tv pictures 3D look alike?Yes,this problems the tv convergence board it is dead to causes this problems.The tv convergence board must have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 16, 2011 | Televison & Video
My RCA 52" projection TV
Try these companys PTS 1-800-844-7871
Encompass Parts 1-800-638-3328
UED 1-800-648-6657
Go to website at Encompass and type in your model number fior list of Parts/Prices
Jun 23, 2011 | Panasonic PT-47WX53 47" Rear Projection...
JUST LOOKING FOR INSTRUCTIONS ON CHANGING THE LAMP.
the d52w20 rca model rca itc22 chasis is a 3 picture tube television.... it has no bulbs... do you mean to change a picture tube?
Feb 28, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I got sound but no picture on my 52 inch rca floor model tv i sure its the bulbs but not sure how can i find the prices or the rite bulb for it
That set is a 1994 model set. You have 3 picture tubes in that set of which are no longer available or made anymore.
Nov 27, 2010 | RCA P56830BL 56" Rear Projection...
RCA HDTV floormodel, model # : HD52w59. The picture does not come in well at all, and the menu is distorted, it seems maybe there might be a bulb out in the left side but I am not sure, how would I fix...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 28, 2010 | RCA HD56W66 56" HDTV
RCA HD R56WH78 projection TV, picture just got ascew,
You are haveing form the sounds of it convergence problems. I see this all the time on this set at the shop. FIrst question in customer menu under setup do you have the convergence option if not consult the tips and tricks section under fl231 problem. if you do have this you may have other troubles the convergence is controled by three seprate boards.
Nov 08, 2008 | RCA HD52W56 52" Rear Projection HDTV
Firmware upgrade
firmware upgrade? i am not aware you can ungrade the firmware on this set this is a rca itc222 chasis. there is service software that allows you to diagnose problems. rca offers no firmware update for this set
Dec 18, 2007 | RCA HD56W66 56" HDTV
Televison & Video Logo
1,713 people viewed this question
Top Televison & Video Experts
Ekse
