Question about SanDisk Sansa m240 MP3 Player
Backlight problems My Sansa m240 player is working great except for the fact that the backlight has now stopped working, coming on. I have tried a new battery thinking that it was too low but that did not help. thanks for the help. mark
  • 626 Answers
If its less than 1 year old, have it replaced. Otherwise, you may want to find someone electronically inclined to replace the internal led light. Best of Luck.
Posted on Sep 12, 2007
Scandisk Sansa M240 in stops transfering tracks at 8% on Napster
go to yahoo find a driver and then reregister napster it should work
Jan 18, 2009 | SanDisk Sansa m230 MP3 Player
Screen frozen when powered on
turn it off, take out the battery, then replace it, turn it back on. see if this helps.
Mar 15, 2008 | SanDisk Sansa m240 MP3 Player
Backlight not working
This can really be a challenge since it's you are no longer able to see the display to change the setting, see if you can shine a fliash light on it so that you can at least read the display to change it. Otherwise see if you can get it to reset to factory default by either taking out the battery or just leaving it on till it is completely drained.
Hope this helps.
Dec 06, 2008 | SanDisk Sansa m240 MP3 Player
Sandisk Sansa M240 Screen Busted
Hard w/o screen, here are the steps:
The Sansa Fuze has a built-in microphone allowing you to record your own voice, an
interview, or a speech.
To start voice recording, follow these steps:
1. Press the Home button to return to Main Menu.
2. Select Voice from the Main Menu.
3. Select Record Now.
4. To pause the recording, select Pause.
5. To stop the recording, select Stop.
6. Select Yes to save the recording.
7. Press the |<< button to return to the previous menu.
Dec 03, 2008 | SanDisk Sansa m240 MP3 Player
How do i get the backlight to go on again on my m240 sansa scandisk? thanks
On my C100 the backlight comes backon when I press the menu button.
Hope that helps.
Dec 01, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Nothing except for "sansa" on the sreen.
there is some problem in sansa's firmware so load firmware from the CD which provided with sansa m240 it will work ...
Jan 15, 2008 | SanDisk Sansa m240 MP3 Player
My Sansa m240 does not play music, it freezes.
Try going into your USB Settings on your device and ensure the unit is set to msc
Jan 09, 2008 | SanDisk Sansa m240 MP3 Player
Why do I have to keep synchronizing?
The message refers to your account with Rhapsody. You need to "Synchronize" with Rhapsody to validate your licenses in which they verify that your account is valid. You should generally receive this message every 15 to 30 days. Best of Luck.
Oct 01, 2007 | SanDisk Sansa m240 MP3 Player
Try formating it via the computer.
May 03, 2007 | SanDisk Sansa m240 MP3 Player
Not enough memory space for music db
Your M240 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M240 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M240 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Disk Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Disk Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M240. The lower section also contains the drive # pertaining to your M240. Right-click on either drive letters pertaining to the M240 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M240 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: Save this file to your Desktop and run it while your M240 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M240 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M240 is a great player
Apr 24, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
