Refrigerators Logo
Whit Davey Posted on Sep 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No cooling in refrigerator and freezer msd2456geq
Lights are on. No cooling in frige or freezer
John Tripp
Level 3:
  • Refrigerators Master 4,656 Answers
  • Posted on Sep 03, 2013
John Tripp
Level 3:
Answers
4656
Questions
Helped
1677640
Points
14883
No cooling in refrigerator and freezer msd2456geq - 60c6a620-8bdd-4642-a307-6b5fcac3e989.jpg
It is possible that the defrost timer has failed while in defrost. The defrost timer can be found inside the control panel inside the fresh food compartment. The defrost timer is location number 13 in the photo=> HERE You can test the defrost timer by going through a small opening in the control panel or by opening the control panel and using a flat head screwdriver and turning the timer dial slowly clockwise until the compressor and fans restart. If this starts the refrigerator again then you will need to replace the timer because it is defective. I am here should you have questions, Sea Breeze
Your model uses a=> 68233-2 Defrost Timer
5 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Oct 25, 2007
SOURCE: GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Anonymous
  • 175 Answers
  • Posted on Jan 16, 2008
SOURCE: GE refrigerator profile arctica Not cooling frige or freezer PTS25LBMARBB
well if the compressor dont have power so how could it work or cool?
A
Anonymous
  • Posted on Jul 15, 2008
SOURCE: refrigerator side not working
The freezer is workig fine but refrigerator side is not cooling.
Anonymous
  • Posted on Sep 16, 2008
SOURCE: ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Anonymous
  • 10865 Answers
  • Posted on May 27, 2009
SOURCE: frige light on not cooling,freezer fan working but not freezing
Hello there. Let me see if I can assist you.
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
2answers
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
It is not cooling as well as it does usually. The freezer is cooling at frige temperture and the frige side is hardly cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
I have a ge frige that the freezer works but frige is warm
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1helpful
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Refrigerator side not working
Freezer works like frig-freezer lite only one working
ch the fan in the frige feel it if is blowing air .or is slow. you need to replace the fan moter.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
