Question about Dryers
Heats but dosn't spin
Dryer heats and starts to spin then stops, but keeps heating
  • claireskmelt Apr 14, 2009
    put a new one on, it broke, put the old one back on!
  • 490 Answers
Change the drive belt
Posted on Apr 13, 2009
  • Jeff Adkisson
    Jeff Adkisson Apr 14, 2009
    something is locked up a bearing or a guide wheel
I get code E6 and my Maytag dryer keeps stopping
BAD MOTOR WINDINGS OR DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Apr 19, 2015 | Maytag Dryers
Dryer starts and about 5 minutes later stops and lights start flashing
DRYER OVERHEATING: Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Mar 22, 2015 | Dryers
I have a TDC6 drier. It starts drying and dryer light is on, but light goes out and it stops drying? Will you be able to tell me what the problem is?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Electric dryer no start does nothing
Oct 10, 2014 | Dryers
Dosn,t heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 13, 2011 | Roper Dryers
Whirlpool Dryer, Heats up, but will not spin.
Thermal fuse , is the small white plastic piece on the blower box . That , keeps the dryer from running . Thermal cut-off , is the small thermostat on the burner (element) box , which would keep the dryer from heating .
Jul 31, 2009 | Whirlpool LER5636P Electric Dryer
Maytag dryer stopped heating /drying
ON THE SIDE OF THE BURNER TUBE THERE IS A RESET THERMOSTAT- IN THE CENTRE U PUSH THE BUTTON.
Jul 08, 2009 | Dryers
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
