Question about Sony MHC-GX450 CD Shelf System
How do I use my Sony SS-WG450 sub woofer and 2 side speakers for cheap without the HCD-GX450 main unit? I bought the 3 speakers but didn't get the main unit and I just need to know how I can use them without spending $300. I an good at wiring and stuff so if there's anything I can do please let me know
4 Suggested Answers
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Sony HCD-GX450 aux input?
on the front of the system
Posted on Aug 01, 2009
  • 198 Answers
SOURCE: what is the voltage to power the sub. model#
If this is a house unit, it'll take 110V AC to power it up, then there is a voltage regulator after that that drops the voltage, so the electronics don't burnout.
Posted on Oct 20, 2010
  • 21 Answers
SOURCE: whats a control jack on a sony SS-WG450
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Posted on Feb 04, 2012
Power supply for Sony speaker system model SS-wg450
How can I power the sswg450 if some one ripped off the place I'm supposed to plug in
Apr 22, 2012 | Sony MHC-GX450 CD Shelf System
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
Ok i just got the sub from a sony sswg450 i want to know is there some way to hook it up to my Pioneer home Receiver
Did you get a manual with it? According to the Sony site this speaker originates in Sony MHC-GX450.
"This product bundle includes the following models:
HCD-GX450 - STEREO MINI SYSTEM
RM-SC3 - REMOTE CONTROL for Shelf Mini Systems
SSRG444 - FRONT SPEAKER FOR MHCGX450
SS-WG450 - SUBWOOFER FOR MHCGX450"
Find the manual here and learn a bit about your seprated sub...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX450
See page 7.
As can be seen, the subwoofer has two connections to the mothership, very unlike the standard speaker level (+/-) speaker wire or RCA-Line-Level subwoofer out that 'normal passive or active subwoofers use, respectively.
Not knowing which of those your unspecified Pioneer receiver supports, it is impossible to say. Does your Pioneer have that control jack?
Mini-systems are generally not designed to be pieced out and used with grown-up gear. The absence of standardized connections is the clue.
Apr 17, 2011 | Sony MHC-GX450 CD Shelf System
I have been given a Sony SS-WSX1 subwoofer. However |I do not have the bespoke cabe. I need the pin out of the sub woofer to connect the unit to my system.
The sub was part of a Sony DAV-X1. This whole system is highly proprietary in its connections for a reason. For all anyone knows, the original amp's output was frequency-shaped to correct for speaker response issues, like Bose would do. Substituting a different amp may be electrically unwise and audibly unsatisfying. It is certain that the DAV base unit did all the electronic magic to create a surround effect from only 2 speakers and a sub.
Your best bet to put these speakers to use would be to examine the sub and speakers for two conductors each that would be for the amplifier's audio output. Measured across them wit han ohmmeter it would read somether around 6 ohms.
Then somehow craft a physical connector to carry an amp's speaker output to it and carefully test it with very low volume.
http://www.retrevo.com/support/Sony-DAV-X1-Home-Theater-Systems-manual/id/750ci463/t/2/
Jan 20, 2011 | Audio Players & Recorders
What is the voltage to power the sub. model# sony ss-wg450
Oct 20, 2010 | Sony MHC-GX450 CD Shelf System
Sony HCD-GX450, locked up.
Electronics have gone to heaven. Bury it and get a new one.
May 08, 2017 | Sony Audio Players & Recorders
My left speaker to my Sony HCD-GX450 stereo is
Make sure that Loudness switch is turned off & bass is not boasted up. Most cars have small cheap speakers that can't handle the bass. also its better to cut the low frequency from the woofer using a passive or active crossover. Most nowadays head units have got some sort of built in crossover. Refer to your head unit manual.
Sep 20, 2009 | Audio Players & Recorders
When iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Jul 09, 2009 | Sony STR-DE325 Receiver
Sony hcd gx450 blinking problem
your speaker are hooked up wrong.or there may be dust in or on the terminals.i used a q-tip with rubbing alcohol and wiped them down.hook up the speaker cords properly and try this again.if this does not work then unplug the stereo and let it sit overnight and try again.
Dec 04, 2008 | Audio Players & Recorders
Sony MHC-GX450 CD Shelf System Logo
186 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
