Question about Kenmore 54501 Dehumidifier
Dehumidifier unit has power but nothing happens. Cleaned filter and coils. Turned down % etc. and still nothing
  • 60 Answers
If it is a manual control try tapping the control with a screwdriver its possible the contacts are stuck and if it is a digital board its possible the board is defective let me know if this works
Posted on Sep 12, 2007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Please let me know if you still have this problem
Posted on Mar 28, 2008
6ya staff
SOURCE:
I have a Delonghi DH250R dehumidifier.It make a clicking noise every now and then when it is turned on. Is it that the thermostat trying to kick in to start the compressor ? And the dehumidifier is not...
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1& 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 06, 2011 | DeLonghi Dehumidifiers
I have a Danby DR401 that I got from a friend, but it won't remove any moisture from my home. The RH% is 79%, the unit is set to 35% and it's been running for 2 days with no moisture being...
There are 5 basic, but solvable reasons for what you described.Numbers 1 & 2, you have already addressed.
in basement applications. Raising the unit up off the floor, level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 25, 2011 | Danby Dehumidifiers
The humidiy control is not working. the only time it will run and when I lower the humidity control to on
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. Your Manually Controlled unit
should be turned to Maximum.
where the air temperature at floor level is colder than at shoulder level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humid-i-stat sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 24, 2011 | Haier HD456 Dehumidifier
The dehumidifier keeps running and not collecting water. registers 75 and turn down lower but no water
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog control
turn the humidity extraction knob to Maximum.
problem.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 16, 2011 | Danby DDR505R Dehumidifier
Fan works. Filters and clean. Heater a Can aster seems warm. Room is damp. Unit does not produce water
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.. Yiu have already cleaned the filter, so that one's covered.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a mechanical unit
turn the control knob to Mai=ximum.
level
problem.
Hope his helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 02, 2011 | Goldstar DH304 Dehumidifier
My unit runs for about 10-15 minutes then shuts off. I cleaned my filter so that is not the problem.
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. (# 2, you have already taken care of)
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled unit, turn the knob to Maximum
in basement application . Raising the unit up off the floor,
problem.
Jul 13, 2011 | Goldstar DH2510A Dehumidifier
The dehumidifier is not putting out any water. The fan is working. There is a lot of humidity but nothing is happening int he bucket thanks
Anya, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
level
problem.
Hope this helps you to troubleshoot the above and solve the problem. Please let me know. Thanks.
Jul 12, 2011 | Danby DDR586R Dehumidifier
Haier Model #455 dehumidifier runs and runs but is not gathering any water from my very damp basement.. . .I have cleaned it thoroughally .. .anything else I can try?
Debi, there are 5 basic, but solvable reason for what you described. Please pay particular attention to number 1 & 5.
level
in basement applications . Raising the unit up off the floor,
problem.
Hope this helped you to further troubleshoot & solve the problem.
Jul 11, 2011 | Haier HDN655E Dehumidifier
Danby premiere mod. unit shuts down after operating for a few minutes
level
problem.
Hope this helps you to troubleshoot & solve the problem.
Jul 09, 2011 | Danby DDR4010E Dehumidifier
Kenmore 54501 Dehumidifier Logo
161 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
