Question about Seagate Barracuda 7200.7 (ST360014A-20PK) 60 GB Hard Drive
Light blue is on, Seems it doesn't start at all
Acomdata External HD s/n A00837839, Model hd25ou2ES-72 The light is on, it makes some kind of clicking noise but won't start. When I turn the switch off the light still on, doesn't it supposed to turn off? My computer is not reading it maybe because it is not working the drive.
  • soyjairo Sep 13, 2007
    Can you please instruct me as to how to take apart the Acomdata External HD s/n A00837839, Model hd25ou2ES-72 external driver?
    Novelist:
    Champion:
  • 254 Answers
Check it on a second computer, if the problem follows the drive, then the drive is defective. You could take the case apart, and make sure the cabling is properly seated. Have seen an external drive where the interface cable (to the drive itself) was not properly seated, and resulted in a non-working unit.
Posted on Sep 12, 2007
SOURCE:
I am having a problem with my external hard drive I look over and the blue light is good on the Acomdata D32OUFAPE5-72 Hard drive and then I go to explorer and it is no longer in my directory as a...
You can remove the hard drive from the case and put it into another, new usb hard drive case. You can buy one for 20-30 dollars. I have seen this many times before. The hard drive is probably okay, but the controller inside the acomdata case is likely dead. Don't worry, just get a new usb hd case.
Hope this helps!
Regards,
Joe
Jan 04, 2011 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata 250 external (SATA) hard drive not showing up on desktop
be safe
go on line to acomdata web site and down load the driver from there
Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
External Hard Drive won't respond
ok 1. you need to be sure that you can`t have acces anymore by usb to the external HD... try in another machine example a other laptop.. or you need to open the HD and connect to other way with a new conector that sell in comusa or other computer store... pls click that my solution was usefull
Dec 27, 2009 | Acomdata E5 HD320UHE5-72 320 GB USB 2.0...
Clicking noise and red light instead of green...need data!!
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Apr 07, 2009 | Acomdata HD120U2FE-72 120 GB Hard Drive
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Drive not recognized by desktop.
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Aug 25, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Hard drive no longer on computer
Aug 10, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Open Questions:
RICOH customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This RICOH USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 RICOH USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the RICOH USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, RICOH USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. RICOH USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact RICOH USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling RICOH USA Calling RICOH USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from RICOH USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with RICOH USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare RICOH USA's phone numbers against each other. Contacting RICOH USA in General While I8OO8O31O69 is RICOH USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach RICOH USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact RICOH USA.
Oct 18, 2019 | Ricoh Computers & Internet
KODAK customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This KODAK USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 KODAK USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the KODAK USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, KODAK USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KODAK USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact KODAK USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KODAK USA Calling KODAK USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KODAK USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KODAK USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KODAK USA's phone numbers against each other. Contacting KODAK USA in General While I8OO8O31O69 is KODAK USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KODAK USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KODAK USA.
Oct 18, 2019 | Kodak Computers & Internet
See all Seagate Barracuda 7200.7 (ST360014A-20PK) 60 GB Questions
Seagate Barracuda 7200.7 (ST360014A-20PK) 60 GB Hard Drive Logo
162 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
