Question about Samsung LE40M91B 40 in. LCD TV
Samsung 40" 1080 DLP TV screen is broken. There is power and sound but no picture due to shattered screen.
Are you a nut case? shattered screen? of course theres going to be NO picture....
Posted on Dec 28, 2009
Have a dlp samsung HLT6176S no picture already replaced the bulb still no picture what gives
Remove the lamp and look at the color wheel that faces it.
If wheel is shattered or missing pieces set will know it is not moving or moving too slow and shut set and lamp off.
Not all color wheels when fail make a sound
May 06, 2012 | Samsung DLP HL-P5663W 56" TV
My Samsung HLP-4667W DLP TV has no picture when I turn it on.
The color wheel can be ruled out by looking at it---it faces the lamp and can be seen---look to see if any segments of the wheel are missing or if the wheel is totally shattered.
Other than the wheel I am concerned by "blue splotches etc" as it might be a DMD gone bad. Look at the attached photo and the color wheel first.
May 03, 2012 | Samsung Televison & Video
We have a samsung DLP tv model number HLP 4663W tv. The picture went so we replaced the bulb. Still no picture and the tv makes a noise that sounds like a fan and the tv cycles on and off by itself. ...
Yes, almost certainly a bad color wheel, see attached photo.
If you remove the lamp and look in the direction it faces you should be able to see the wheel, look for it to be missing pieces or shattered.
You Tube has detailed video instructions for replacement in most of the Samsung sets; I have replaced dozens of the wheels.
Before you rate my solution let me know if you have any questions by commenting here.
SD TECH
Jul 08, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
Have a 61" dlp samsung tv, making a humming sound
Bad Color Wheel.will cause this and it is a common problem for DLP Samsungs.
Part number is BP96-01103A
Samsung Parts 1-800-627-4368
Jun 24, 2011 | Samsung HLR6178W 61" HDTV
Signs that the bulb in a dlp is going out
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
Apr 12, 2010 | Samsung HL-67A510 67" DLP HDTV
NO POWER
If there is no standby light or any blinking LED lights, check the outlet first to make sure you are getting power. If so, then the power supply board in the TV has failed. If you are getting blinks and just no picture or sound, it will be something else depending the sequence of blinks.
If you are getting blinks, I would check the lamp first. This is the most common failure. Look for either a cloud near the stem of the bulb or if it is shattered, replace the lamp.
Oct 07, 2009 | Samsung DLP HL-P5663W 56" TV
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
No sound or picture
the most likely cause would be the lamp, you can pull it out and check. most of the time when the lamp blows the center of the lamp will shatter
Feb 20, 2009 | Samsung HL-R4264W 42" DLP HDTV
Open Questions:
See all Samsung LE40M91B 40 in. LCD TV Questions
Samsung LE40M91B 40 in. LCD TV Logo
145 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
