Question about Craftsman 10" Table Saw
Saw will not run
The craftman table saw will not run/start. was cutting shut off saw. went to turn on saw nothing happened. checked power sourse, ok. reset button seens ok. this is the 5th or 6th time used saw. what can I check or do to get the saw to run?
I had the same problem several months ago with a craftsman (shut down during a long rip), and the reset switch had tripped but did not actually pop out. I tested everything in the line between the power supply and the motor, and found out that the reset switch was not conducting. I was able to reset it manually before re-installing it into the saw, and it's been fine ever since. I'd test that before you start pulling the motor out, it would be a much easier fix if the switch was just sticking.
Posted on Apr 28, 2009
  • ljk187 Apr 28, 2009
    See here for more details, I posted a full solution to this before:
    http://www.fixya.com/support/t914144-cra...
I have the same problm with m Craftsman model 137.248830. I have found that the switch cover under the saw fills with fine sawdust over time and will overheat the cutoff switch. I have to invert the saw, pull the switch cover off and clean the saw dust out with a tooth brush and then everything seems to be fine again. Seems like a sealed cover would be a big help so I may try to make a gasket to help seal out the dust next time I have to dismantle the switch cover! good luck!
Ron
Posted on May 02, 2009
    Genius:
  • 1,605 Answers
First check the saw with power off and unplugged from the wall socket.
turn the blade by hand, if it is hard to turn, check the motor for object that is logged in the motor. if you can't find any, then you have a burned motor. if it is not, check the motor for broken wire and burn saw dust. do what ever you need to do to correct the problem.
Posted on Apr 13, 2009
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Overload reset button on porter cable 10 in table saw
Why this is in sewing machines I will never know.
But this is an example of pushing a saw beyond it's limits. At best you should have cut one post, shut the machine off and let it cool... then go for the next. (Better yet get a friend with a saw mill saw the thing down for you)
I believe you have burned out your motor. Off the store you go....for a new one.
Oct 25, 2013 | Sewing Machines
I have been using my Craftsman 10" Table Saw to
First things first, check the outlet that the saw is plugged into. Does it have power? If so then progress to the saw itself and check the reset button which is usually located on the front panel but sometimes on the back or sides. Press the button firmly to make sure it is not tripped and if it is this will reset it. Make sure the power is turned off and attempt to turn the blade manually ( caution,
the blade is sharp so a pair of gloves is recommended ). If the blade turns with very little resistance then turn the power back on and try the on/off switch. If the saw starts it may very well have been the circuit breaker that had tripped.
Mar 02, 2011 | Craftsman 10" Table Saw
Saw stopped working mid-cut as if power loss. Blade turns freely, was no unusual odor. Reset button no help. No problems prior to that event. This is a Craftsman 10" table saw.
Could be the motor burned out. That shouln't happen and if it did craftsman is really good at replacing damaged tools. I'd return it for a replacement.
Mar 04, 2010 | Craftsman 10" Table Saw
Table saw not turning on
yes that is a thermal fuse. wait a couple of minutes and reset it. If the blade is dull, replace it.
May 02, 2009 | Vacuums
My Skil Saw 10 will not start now.
depends wether the saw is belt driven or gear. just because you cant hear the motor doesnt mean its not running.
Apr 25, 2009 | Skil 10" Table Saw 3400
Table saw won't turn on.
Check that a breaker has not been thrown, and there is power to the plug that you are using.
Reply your findings if this isn't it, and I will give you additional help.
Jan 19, 2009 | Saws
Craftsman 10" Table Saw Logo
669 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
