Question about Panasonic SC-DK2 System
Humming noise When I turn on the system it makes a loud humming noise that also can be heard during the playing of the movie. What could be the problem? All the cables seems to be fine. [email protected]
  • 752 Answers
Does it come out of all speakers or only certain ones?
Posted on Sep 12, 2007
SOURCE:
Car makes loud humming noise when idling
there can be a crack on exhaust manifold or on eghaust muffler.
Apr 11, 2014 | 2000 Toyota Tundra
Humming noise when i turn the key on in the morning
power steering pump make humming noise and alternator with bad shaft bearing make noise.
Feb 12, 2013 | 2005 Toyota Sequoia SR5
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Maytag Dryers
Humming sound when Sony DVD player is turned on. The player is attached to a TV. The sound continues when a DVD movie is played.. The intensity of the humming changes with changes in the Video.
Is the humming just from the power on or is it when the DVD is spinning some media will spin with a loud humming noise something to do with the balance similar to an unbalanced car wheel, just a lot quiter. Burn the DVD using ImageBurn create an ISO and reburn.
If it hums without the DVD spinning it is probably the transformer on the PSU on it way out this can happen at any time it is caused by the voltage step down coil becoming damaged in some way and the lower voltage provided causes the noise.
If this is the case I suggest a new PSU or at least a new Transformer.
Jan 07, 2010 | Televison & Video
Yamaha pt300. was working fine. Now only makes loud humming noise which doesn't repsond to change in volume. Monitor display shows keys register as being played, but no sound can be heard except loud...
Likely the power adapter has failed if it uses one. Try a new one first.
If half the rectifier blows out, a very impure DC voltage is applied which will be heard in the audio output.
Sep 27, 2009 | Dean Dimeblade Tribute Electric Guitar
GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Dave
Jul 16, 2009 | Microwave Ovens
Ilo DVDR05 Vibration and loud humming noise
i experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
May 17, 2009 | iLO DVDR05 DVD Recorder
Loud Humming Noise
You're describing vague, conflicting information. At first glance, I would think you have something stuck in the pump. But then it would be there in the rinse-only cycle also.
The anti-bacterial mode heats the water up to about 180F. This kills bacteria, and it also speeds up the action of the detergent. It could be dissolving whatever is in there.
The humming noise wasn't there in the rinse mode... The heater isn't on in the rinse mode - everything else is. But I've NEVER heard a heating element hum.
Cleaning the filter:
The filter is in the back in the bottom right. It's cover is held on by two 1/4 in screws. Under that is a large grate, and I sometimes find stuff clogging the screen (underwater, toward the center of the machine.) I'd start by looking there.
Mar 23, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Panasonic SC-DK2 System Logo
241 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
