Question about Intel Motherboard
Cmos problem When i clear cmos via jumper setting system will diplay boot menu. after resatrt my system ther is no any display. and i m also change the cmos battery new one. But New Scond time display. it's Idel Now.
  • Anonymous Apr 14, 2009
    when open my to load xp it load but when the option of partiton not come .
    President:
  • 1,383 Answers
Checkcu fix jumper in its 1-2 position
also refix ram
also check dispaly cable is fixed properly.
Posted on Apr 13, 2009
I'm faced with a black monitor, no boot beep, with an operating fan and green light on. XP OS with an ASUS P5P800S motherboard, Thanks Jose
Remove all components from your mb and bios battery. Place jumper to clear cmos and make short to battery cmos. Leave 1min and after place cpu and one ram in mb. Replace jumper from clear cmos in normal position and verify. If not display, change ram.
Sep 26, 2014 | Computers & Internet
Tip
How do I reset my BIOS/CMOS to defaults?
Let's get to it!
There are two ways to reset your BIOS/CMOS, the first way is to locate the three pins that relate to the BIOS/CMOS clear header. If the jumper is over pins 1 and 2 it represents normal operation. Therefore to clear the BIOS/CMOS one would place the jumper over pins 2 and 3 for about 15 seconds.
Now remember that the BIOS chip is a EEPROM, this means that it will store information so long as it has suffiecient power, from a power source. In this case it is a silver button cell located on the mainboard, usually of size CR2032 3Volts. Once the jumper is placed over pins 2 and 3 for about 15 seconds, quickly place the jumper back to the normal position, which is over pins 1 and 2.
The second way to clear the BIOS/CMOS is to simply remove the BIOS/CMOS silver button cell, for about a minute and then reinstall it in the correct orientation.
Well thats it, now you will be able to boot your system on the defalts settings. Remember to enter the BIOS/CMOS by hitting the approprite key during Power On Self Test. There are many different keys, depends on your computer system. Common ones are Delete another is F12.
Enter the BIOS/CMOS to correct the date and time and to set the boot priority.
Shown below, on the left, the silver button cell of size CR2032, centre, a yellow jumper on the clear BIOS/CMOS header, on the right, the BIOS/CMOS.
All the best!
damnor01
on Dec 12, 2010 | Computers & Internet
Changed cpu multiplier from 17 to 19 now have blank screen on foxconn a88gmx, cant reset as cannot access bios
Try clearing the CMOS --- the down side is your lose all your setting --- the up side is you should be
able to access your BIOS
Clear CMOS Jumper: CLR_CMOS1 ( Located near CMOS battery )
The motherboard uses CMOS RAM to store the basic hardware information (such as BIOS data,
date, time information, hardware password...etc.). Clear CMOS data is the fast way to go back to
factory default when the BIOS settings were mistakenly modified.
The steps to clear CMOS data are :
1. Turn off the computer, unplug the power cord from the power outlet.
2. Remove jumper cap from pins 2-3, put it onto pins 1-2 to short them.
This will clear CMOS data.
3. Return the setting to its original with pins 2-3 closed.
4. Plug in the power cord to your computer and turn it on.
5. Go to BIOS Setup to configure new system as described in next chapter.
Clear Jumper on pins 1 & 2
1 ----
2 ----
Normal
(Default)
3 ----
CLR_CMOS1
  • Disconnect the power cable before adjusting the jumper settings.
  • Do not clear the CMOS while the system is turned on.
WARNING!
Jumper Diagram Definition Description
1-2 Set Pin 1 and Pin 2 closed
2-3 Set Pin 2 and Pin 3 closed
Feb 10, 2011 | Foxconn A88GMX AM3 AMD 880G HDMI Micro ATX...
After replacing on board lithium cell, computer will not boot up. Goes through BIOS ok but no further, even tried replacing hard disk and booting from removable media drives (after setting BIOS...
Did you swap the Cmos jumpers from 1-2 to 2-3 to clear Cmos before replacing battery and if so, did you return them to their original position (normal as opposed to clear cmos)? If the jumper is still in the clear Cmos position, the board will not boot.
Try changing the Cmos battery, it may appear to work but may not be suited to the board
Disconnect all drives except the hard drive, unplug usb and sound cables, if fitted, remove graphics card and either test with another one or use the onboard graphics.
Jan 11, 2011 | ASUS A7V333 Motherboard
After cmos save display not coming? when clear
If you have cleared the bios (cmos) at the jumpers....must be off the jumper for at least 1 minute! then your problem is the hard drive, either replace it or reinstall your operating system
Jan 05, 2010 | MSI K9MM-V Motherboard
No post screen, cant access cmos settings. but windows starts as usual just a blank screen til then?
Its possible that your cmos settings were changed prior to this problem so as not to display cmos settings options at boot up. Have you tried resetting your cmos settings to fix the problem? You can do this by a jumper which is usually found on the mother board named "clr cmos" (clear cmos).
Let me know if this is of help or not.
Regards,
Graemevm
Apr 25, 2009 | Dell Dimension 2350 PC Desktop
Toshiba Protege 2000 Lost BIOS Password
if you are getting password in the booting of the pc then it is bios password plz check the link
http://www.tech-faq.com/reset-bios-password.shtml
if it is not then try to boot in the safe mode and change the password
Jun 24, 2008 | Computers & Internet
Please help me
Hi
Check ASROCK P4i45GV R5.0 User Manual Page 17 - http://download.asrock.com/manual/P4i45GV%20R5.0.pdf
Note: Check Page 11 for the CLRCMOS0 location on the motherboard. From the picture CLRCMOS0 is number 18. You can locate CLRCMOS0 just below the CMOS Cell Battery.
Turn off the computer and unplug the power cord, then use a jumper cap to short the pins on CLRCMOS0 for 3 seconds. Please remember to remove the jumper cap after clearing the CMOS. If you need to clear the CMOS when you just finish updating the BIOS, you must boot up the system first, and then shut it down before you do the clear-CMOS action.
Regards
Mike
Mar 22, 2008 | Asrock P4I45GV R5 Motherboard
Loses CMOS settings
there is a jumper near the board cmos battery. try to clear cmos by changing the jumper to the other position for some seconds (while power is off) so smos is clear.
turn the pc on hit delete to enter setup and load system defaults then exit saving configuration.
Nov 11, 2007 | ASUS P4S800D-X Motherboard
No display
The first thing to try, is to look on the motherboard for the CLRCMOS2 terminal pins, this allows you to clear the data in CMOS. The data in CMOS includes system setup information such as system password, date, time, and system setup parameters. To clear and reset the system parameters to default setup, please turn off the computer and unplug the power cord from the power supply. After waiting for 15 seconds, use a jumper cap to short the Clear CMOS jumper for 5 seconds. After shorting the Clear CMOS jumper, remove the jumper cap. If you have changed the ram make sure it's compatable, but if the above has
Jun 12, 2007 | Asrock K8Upgrade-VM800 Motherboard
Intel Motherboard Logo
70 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
