Question about Kitchen Ranges
Want to connect to a 20lb propane bottle. what do I need?
Can I connect my Coleman stove 5466A to a 20 lb propane bottle? How?
  • 490 Answers
You sure can go to academy in the camping supplies and you can get all of the parts to do it there
Posted on Apr 13, 2009
How do you connect the propane to the stove
Assuming you are referring to the Coleman Campers Grill Stove which is a side by side grill and stove unit than it is a pretty simple set up. All portable Coleman stoves set up basically the same. There should be a arm known as a regulator that came with the stove. The narrow end of this attaches to the right side of the stove and screws in. Then the propane bottle screws into the other larger end. make sure all connections are screwed together tightly. For more clarification check out these instructions:
http://www.ehow.com/how_2106008_use-coleman-stove.html
https://www.youtube.com/watch?v=dbYil-YQ8-Y
Good Luck!
Jul 07, 2014 | Coleman Campers Grill
Can a 20lb tank be hooked up to a Coleman 2 Burner Stove 5430A
Yes. There are multiple adapters made to fit this application. Your local walmart most likely will have them. http://www.walmart.com/ip/Coleman-5-High-Pressure-Propane-Hose-and-Adapter/19897422
Sep 18, 2013 | Coleman 2 Burner Propane Stove 5430E700
Purchased RMC-8001SS in 2005. I am working in a 12X12 shop and want to hook up with a 20lb propane tank. Need schematic, part numbers etc. Company contact 100% busy signal. Can you help?
try your local u-hall they just might have the goodies you need to get a bigger tank hooked up, also harbor freight has a tank filling attachment
Item # 45989 Manufacturer: MacCoupler
This propane refill kit lets you refill your 16.4-oz. propane bottle from a 20-lb. propane tank, and save money about $20.00.. this could help you get by till then .. jay the pump guy Florida
Feb 07, 2012 | Dyna-Glo RMC-8001SS Heater
My Mr Heater Buddy heater 4000 to 9000 btu unit work fine with 1 lb propane tank but when I connect it to my 20 lb tank with hose it will not stay lit. Acts like there is not enough gas pressure. My 20 lb...
it could be down to the draw off the tank pipe too small or reg is not for a 20lb tank , going to lock out check reg pressure should say on the side , or take hoes and reg off tank , put it back on and turn gas on slowly see if this helps
Jan 30, 2011 | Mr. Heater Mr Heater Portable Buddy...
When commected to 20 lbs tank the pilot light does not stay on; however, when connected to a 1 lb propane bottle everything works propertly. I have replaced the fuel filter, I have tried using different...
The new 20lb LPG cylinders now have what called an OPD Valve. Reconnect to a 20lb cylinder and turn the tank valve on very very slowly, This will help prevent the OPD Valve from locking up the heater's regulator. Your 1lb cylinder is not required to have this OPD Valve.
By the way, this happens quite frequently with LP Gas Portable Grills.
Jan 25, 2011 | Mr. Heater Mr Heater Portable Buddy...
I have a ProCom ML150HPA for propane and would like to use a 20lb bottle the manual states that at least a 100 lb tank is required. With the 20 lb the pilot lights but will not stay liit without the...
The reason for a larger tank is so the LPG can vapourise enough to supply the heater using a smaller bottle it may freeze and not produce enogh gas
Dec 13, 2010 | Procom MN100HPA Heater
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Could not get more then 72hours using 20lb tank on low
HI. propane has 91000 btu's per gallon. 20# bottle has 4. divide btu's of heater by #of gallons for hours of use. I have the same heater and I think the med. setting both burners on is more the 7000 btu's.
Mike
Nov 25, 2008 | Dyna-Glo Double Tag-a-long Heater
Kitchen Ranges Logo
230 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
