Question about HP LaserJet 1200 Printer
Line printing down paper
Its in the same spot. I changed toner, still there
  • lgmasonpc Apr 14, 2009
    can i fix this? clean or does it need to be replaced or buy new printer? Thanks.
Fuser sleeve is failing
Posted on Apr 14, 2009
  • Anonymous Apr 14, 2009
    Not an easy job for an end user, and would take a few hours (plus parts) to resolve anyway. So, for the price of a new entry level laser printer these days - $80-$100 (basically the price of a toner cartridge), that's the route I'd go.
    please rate solution :)
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
Black spots on paper - Ricoh Aficio MP2000
If it uses a cartridge, check for leaks. If a leak is found, there may be toner scattered inside the copier
Oct 11, 2012 | Ricoh Aficio MP 2000 Black and White...
I have an HP 4515 and we are getting black spots on various pages. Is it time to replace the fuser assembly
Put paper in the manual feed tray. Print a few pages. As the paper gets pulled half way into the printer, open the top cover, pull out the toner and look down at the paper. If you see the spots replace the toner. If you don't see the spots replace the fuser.
Nov 22, 2011 | HP P4515n LaserJet Printer
4 faint lines running vertically down the sheets of paper
just open the printer cover and clean the toner with tissue paper and make sure the toner is not damage othewise you have to replace the toner.
Sep 09, 2009 | Samsung ML 2010 Laser Printer
Printing a blank line down my page. Seems to be etched in the paper
You toner is probably bad. Trying changing the toner. If you still have the same problem after that, something maybe blocking the laser scanner. You maybe able to clean the optics yourself, but it could be difficult.
Sep 02, 2009 | HP LaserJet P2015 Printer
BLACK LINE ALONG RIGHT SIDE OF LETTER SIZE PAPER
Is this and Okidata C5100? And is the stripe vertical up and down on the page? I'm going to assume yes to both of those for the sake of trying to help. Worse case is the fuser unit in the machine is wearing in one spot and thats why the streak is appearing. Also, many color printers require a seperate drum unit or photo conductor unit. These could have a wear spot on them as well. They can fail long befor the change drum light appears. Other than that remove and inspect the black cartridge. If there is a shutter on it, pull back and inspect the two inner rollers. You're looking for any wear spots in a location that corresponds to the streaks on the paper...or an excessive amount of toner leaking from one spot on it. Hope this helps!!
May 21, 2009 | Office Equipment & Supplies
Line down the right stide in the megenta area of the self test and blurrred print on the right side
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Oct 31, 2008 | HP PSC 2175 All-In-One InkJet Printer
Spots on paper
Look on the image drum (bottom of toner cartridge) are there spots on that?? if so clean carefully so as not to damage it or replace the cartridge. If this is not the case open the cartridge door during a print, but before the paper fully enters the fuser and check if the spots are already there, if not the fuser is causing the problems.
May 14, 2008 | Lexmark E321 Laser Printer
Dark spots on my paper
is there a corona wire sliding cleaner on the drum assy? if so it should be firmly at the correct end of its travel - on some printers if it is inboard it will print aline down the side
Apr 18, 2007 | Kyocera Mita FS 3800 Laser Printer
HP LaserJet 1200 Printer Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
