Question about Microsoft Windows XP Home Edition
Hi, ihave a dell latitude d600 when i start up i get windows gui up, then i get a stop c000021a fatal error message stating that session manager sys process has terminated with a status of: oxc oooo26c (0x00000000 ox00000000 ) system is shutdown, Has anybody got any suggestions please. kind regards mike
    Guru:
  • 846 Answers
  1. Start your computer to the parallel installation of Windows NT, and then start Registry Editor.
  2. On the Window menu, click HKEY_LOCAL_MACHINE on Local Machine.
  3. On the Registry menu, click Load Hive.
  4. Type the path to the System hive of the prior installation, typically %systemroot%\system32\config\system, and then click Open.
  5. When you are prompted for the name of the key, type TEST, and then view the following registry entry: HKEY_LOCAL_MACHINE\TEST\Select
  6. Note the setting for the Current DWord value in the preceding registry key. This is typically 0x1, and is represented as CURRENT:Reg_Dword:0x1. This value indicates that the "CurrentControlSet" for your original Windows NT installation corresponds to ControlSet001 in this window. A value of 2 would indicate that the "CurrentControlSet" for your original Windows NT installation would correspond to ControlSet002, and so on.
  7. Locate the following registry key HKEY_LOCAL_MACHINE\TEST\ControlSetXXX\Control\Session Manager where XXX is the CurrentControlSet that you identified in the preceding step.
  8. Under the Session Manager key, note and then delete any PendingFileRenameOperations entries.
  9. Click the TEST hive, and then click Unload Hive on the Registry menu.
  10. On the Registry menu, click Load Hive.
  11. Type the path to the Software hive of the prior installation, typically %systemroot%\system32\config\Software, and then click Open.
  12. When you are prompted for the name of the key, type TEST2.
  13. Remove any PendingFileRenameOperations entries in the following registry keys: HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnce
    HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnceEx
  14. Click the TEST2 hive, and then click Unload Hive on the Registry menu.
  15. Quit Registry Editor, and then restart your original installation
How and Why to Perform a Parallel Installation of Windows NT 4.0http://support.microsoft.com/kb/259003/EN-US/
Posted on Apr 13, 2009
Wont start up. c000021a fatal system error 0xc000026c (0x00000000 0x00000000)
your computer has dumping error hard drive, the only way you can fix this error is by format your hard drive and reinstall your windows, but you will lost your data at drive C:
use windows cd or recovery cd to do that
i hope this helpfull
thanks for using fixya
Jan 27, 2011 | Dell Latitude D800 Notebook
My dell pops up with a blue screen and says "STOP: c000021a (Fatal System Error)"
To resolve this issue:
  1. Create a parallel installation of Windows NT.For additional information how to do so, click the article number below to view the article in the Microsoft Knowledge Base: 259003 How and Why to Perform a Parallel Installation of Windows NT 4.0
  2. Start your computer to the parallel installation of Windows NT, and then start Registry Editor.
  3. On the Window menu, click HKEY_LOCAL_MACHINE on Local Machine.
  4. On the Registry menu, click Load Hive.
  5. Type the path to the System hive of the prior installation, typically%systemroot%\system32\config\system, and then click Open.
  6. When you are prompted for the name of the key, type TEST, and then view the following registry entry: HKEY_LOCAL_MACHINE\TEST\Select
  7. Note the setting for the Current DWord value in the preceding registry key. This is typically0x1, and is represented as CURRENT:Reg_Dword:0x1. This value indicates that the "CurrentControlSet" for your original Windows NT installation corresponds to ControlSet001 in this window. A value of 2 would indicate that the "CurrentControlSet" for your original Windows NT installation would correspond to ControlSet002, and so on.
  8. Locate the following registry key HKEY_LOCAL_MACHINE\TEST\ControlSetXXX\Control\Session Managerwhere XXX is the CurrentControlSet that you identified in the preceding step.
  9. Under the Session Manager key, note and then delete any PendingFileRenameOperationsentries.
  10. Click the TEST hive, and then click Unload Hive on the Registry menu.
  11. On the Registry menu, click Load Hive.
  12. Type the path to the Software hive of the prior installation, typically%systemroot%\system32\config\Software, and then click Open.
  13. When you are prompted for the name of the key, type TEST2.
  14. Remove any PendingFileRenameOperations entries in the following registry keys: HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnce
  15. Click the TEST2 hive, and then click Unload Hive on the Registry menu.
  16. Quit Registry Editor, and then restart your original installation.
Sep 30, 2010 | Dell Latitude D600 Notebook
I can't get into windows of my Dell Optiplex GX620. I try but the computer gives the following message: <<Stop C000021a. Fatal System Error. The session manager initialized system process terminated...
You most likely have a hardware issue. Very possibly memory.
You'll need to troubleshoot that by disconnecting everything in the case but the video, CPU, and memory and see if it starts OK.
Then hook up the hard drive and see if you can boot into Windows. If you can't, unplug one of the memory sticks and try it. Then the other memory stick and try.
If you have a Windows startup (installation disk), boot from that and opt for system repair. You will want to get to the command prompt and run chkdsk.
See my tip here:
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
Jul 29, 2010 | Dell OptiPlex GX620 PC Desktop
Stop: c000021a {fatal system error}
start in safe mode with command propmpt and type chkdsk /r/f and let the system get scan.
Jan 20, 2010 | Dell Inspiron Notebook
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
Sep 16, 2009 | Microsoft Windows XP Professional With...
Computer Blue Screen of Death
burn this disk as an .iso and boot from disk. try the recovery options on this disk first, and if nothing then you may be in need of a free OS install. you MUST keep all virus, spyware, and firewall up to date n order to keep your computer safe. free-avg.com does have a great free download.
Good Luck
Mar 12, 2009 | Computers & Internet
Blue screen of death.
Try re-seating the RAM (memory sticks) with the system turned off. Clean out any dust from inside the PC, especially on the CPU fan.
Stop: C000021a (fatal system error).The session manager initialization system process terminated unexpectedly with a status of 0xc000003a (0x00000000, 0x00000000)
Most places will tell you you're boned, but there is the option of using a live cd, such as Knoppix. The following website has a little bit of background on the problem, and how he fixed it.
http://healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-fatal-system-error-with-knoppix/
Hopefully that helps.
May 04, 2008 | Edimax EW-7117U Wireless Adapter
Microsoft Windows XP Home Edition Logo
200 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
