Np wireless connection..
My wireless network adapter is not listed under network adapters, and i ca'nt connect to a wireless network..
  • 35 Answers
Hey
which laptop is it or if it is desktop check under device manager if we have the ethernet controller available under other devices
check their properties and go to pcidatabase.com and find out teh manufacturer for the device and download the drivers
Posted on Sep 18, 2009
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
How do you install the wirleless router?
1. Click Start, and then click Control Panel.
2. Click Network and Internet Connections.
3 Under or pick a Control Panel icon, click Network Connections.
4. Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
And Thanks.
Mar 18, 2010 | Linksys (WMP54GS) 802.11g/b Wireless...
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN XP
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 09, 2009 | Dell 1450 (D1450U) Wireless Adapter
How do you connect WIndows Vista to Windows 7 through ADHOC?
Dec 04, 2009 | Computers & Internet
My wireless adapter does not detect any reception from the router. i have another laptop at home that could easily detect reception from the router. what should i do?
since the laptop is connecting to the router and is having the internet access as well then clearly the problem is with the adapter or with the pc using the adapter.
Following steps can be considered :-
1)If the PC is using OS as windows XP then , click on start menu and then go to control panel and then open network connections from there.
2)Under network connections an option for wireless connection exist , right click on that option and then click on properties.
3)Under wireless network connection properties there are three tabs general , wireless network and advanced.
4)Left click on wireless network tab and check the box which says use windows to configure my wireless setting's and click OK at the bottom.
5)Then , Right click again on wireless network connection and then left click on view available wireless network.
6)List of available networks will be there , select the network you use and try connecting to it , if it gets connected then the internet access will be there.
Nov 15, 2009 | HP 290563-B21 Network Adapter
Need to know if the acer aspire x1300 has a wireless network adapter already installed and if so how do you turn it on.
you will need to check that in the Device manager list.
what is the operating system on the laptop.
Cleck Start ==> control panel ==> network connections.
If you see the wireless network connection under the network connections then there is a wireless adapter on the laptop.
You will just need to connect to the network .
Click Here for step by step solution
Oct 30, 2009 | Acer Computers & Internet
CAN NOT CONNECT WIRELESS ADAPTER SO AS TO USE MY LAPTOP WITH SKY BROADBAND
i connect to the wireless adapter its very easy go to the wireless adapter & refresh to the network list if your notification area will have a wire less network when the wireess adapter search any connection then you see a option connect then click connect
Sep 17, 2009 | Adapters.com Computers & Internet
Can i use Bluetooth USB Adapter to connect PC to wireless router?
No, I am afraid not. the bluetooth adapter will not connect to your wireless router because as of now there is no router that support that function.
you can buy a USB wireless adapter instead.
thank you for using Fixya
Aug 03, 2009 | Linksys (USBBT100-CA) Bluetooth Wireless...
Making my desktop pc wireless
There is no built-in wireless LAN support in Windows Me, Windows 98, or Windows NT 4.0. Wireless network adapter manufacturers must supply all wireless and authentication functionality for these versions of Windows.
To configure a wireless client computer running Windows Me, Windows 98, or Windows NT 4.0, you must use the wireless configuration tool provided by your wireless network adapter manufacturer. Please see the instructions for the wireless configuration tool to configure 802.11 and 802.1X authentication settings.
Apr 19, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Wireless connection disapeared from computer
Hello!
I am not sure exactly where you are checking for Wireless connections.
Anyhow, now a days we are hearing many Wireless adapter missing from Device manager issues.
Please get back to us with the Brand name of your laptop, OS installed.
Also check in Device manager for Wireless adapter.
Please follow these steps to open Device Manager:
1. Right Click on 'My Computer' icon on Desktop and choose Properties.
2. The System properties Window opens.
3. Click Hardware tab and then click the Device Manager button.
Expand + Network adapter and check if the Wireless adapter is listed there or not.
If it is not listed there, then the issue is with the Wireless adapter itself.
This is most comon issue in HP COMPAQ notebooks.
if you are not aware of the Wireless adapter under + Network adapters in Device manager, then get back to us with the complete information under + Network adapter.
So thatI can help you in better way
Aug 09, 2008 | Computers & Internet
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
