Question about Ovens
My oven won't start. no display, only beeps on certain functions
240 v is ok, oven light works. no diagnostic codes. happened once before with an ff3? code that i was able to reset and it started working again. this time nothring happens excepts the beeps. i believe that the original failure code indicated an open clock circuit
  • 1 more comment
  • bultmand Apr 13, 2009
    i posted this in the section that asks for the make and model, but maybe that appears separately from the question section.
    it is a whirlpool GBD307
    when the error code showed in the past, it was E6 F2, not what i put in the posting. it seems that this is a common problem so maybe the forum will help me.
    thanks
    i will try to perform this troubleshooting. first, i need to find out how to get the control panel off.
  • Michael Masters
    Michael Masters May 11, 2010
    whats the make and model of this oven?
  • 6,784 Answers
Hi, the actual circuit that is open is the cancel key connection. Here is a check list that will help. I would consider replacing the ERC if the control is integrated.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Please rate and god bless:)
Posted on Apr 13, 2009
  • Michael Masters
    Michael Masters Apr 14, 2009
    Most control panels are easily released from the back side. there are usually clips and a few screws that are holding it against the control panel housing. when you open the oven door, you can see most screws above the top oven door seal and most side screws are located on the front side corners of the control panel housing.
  • Michael Masters
    You can pull up a part list and exploded view of this oven. this will help with the disassembling of the control panel. The actual breakdown of the panel is on page 8. the link is below.
    http://shared.whirlpoolcorp.com/assets/p...
    Copy and paste that in your browser.
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
Oven wouldn't light so I replaced the igniter. It now lights fine at start up, but won't light when oven needs to reheat.
Certain igniters work together with the oven gas valve that senses current, once they get hot, may not function properly. Was the igniter lighting up at all before? Could also be the temp sensor.
Oct 27, 2013 | Whirlpool Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
GE single oven with touch pad settings. Getting error code F-4 after selecting any bake or broil function keys. Oven light works, fan for convection oven seems to be working. Makes no unusual noise. will...
Hi, the F2 error code means that the oven is overheating for an unknown reason. F3 and F4 indicate a problem with the oven sensor, which usually requires replacing the sensor.
Jan 21, 2011 | GE Ovens
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
Ovens Logo
251 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
