Question about Honda Pressure Washer PSI 3000
Compressor started leaking while using sprayer.Now engine won" bu
Compressor started leaking while using sprayer. Used it until leak got bad. Tuned it off. Now I have taken it out to see if I can tell if it is a gasket or what. But can't budge the engine. It seems froze . Oil is OK
  • 3 more comments
  • waking2 Apr 16, 2009
    This is 3600 PSI HONDA 13 hp EXHP 3640 COMPRESSOR # RKV4G36. IT STARTED LEAKING COPRESSOR OIL. I CONTINUED USING IT UNTIL I FINISHED MY JOB. IT WOULD START DURING THE TIME I USED IT. NOW I HAVE TAKEN IT OUT TO SEE WHY COMPRESSOR IS LEAKING AND THE ENGINE WILL NOT TURN.
    PLUG IS DRY. WHEN I SAID ENGINE WON'T TURN OVER I MEAN I CAN'T MAKE THE PULLEY TURN.I HAVE TO GET ENGINE TO RUNNING SO I CAN TRY YOUR METHOD OF CHECKING LEAK IN COMPRESSOR.
    I must not be explaining myself well enough. When I pull on crank rope it will not budge . It is like it it froze up. I think you are on right track but please advise if I am not wording it right for you to understand. Thanks
  • waking2 Apr 17, 2009
    Is this a guess ?? How did u come to this conclusion ?? Can it be fixed by amertuer or does it need to go to shop ???
    The engine oil is full and has always been. The oil comming out of the copressor was a silver color.Had I run it out of oil it would have killed itself. As I stated I was still able to crank it when I put it away.
  • 15,935 Answers
The pump was able to run (crank) when still warm because it was still thermally expanded.
now that it has cooled - the pistons and block have shrunken, and the pump has seized.
The silver stuff you saw extruding was bits of aluminum from the block!! Theres nothing else in there but oil.
I would venture to say you have at minimum blown a piston seal!
You will need a new pump. If the piston has scored the inside of the block bad enough, replacement is your only option.
Thanks for using FixYa!!
Posted on Apr 18, 2009
    Top Expert:
  • Honda Master
  • 80,339 Answers
Please explain what is leaking?
Posted on Apr 17, 2009
  • yadayada
    yadayada Apr 17, 2009
    the oil u saw was not compressor oil but engine oil getting into the compressor due to a piston or broken ring in the engine, you ran the engine out of oil and now it is frozen up.
  • 195 Answers
You have destoreyed valve/piston assembly,crankcase will not turn because piston head is seized inside cylinder.
jj505
  • Honda Master
  • 19,396 Answers
Check and eventually replace the hose from the filter to the gun. Clean the compressor with gasoline, then put it in pressure and release it trying to blow as much oil through the lines as possible. This will let you know where the leak is.
Posted on Apr 16, 2009
  • Ginko
    Ginko Apr 16, 2009
    I the engine wont turn, check the spark plug, if the leak is from engine block, then the plug is probably soaked in oil.
  • Ginko
    Ginko Apr 16, 2009
    To start the engine check the spark plug, check air intake, and leave engine to rest for a while, if it does not start check if fuel is getting to carburetor.
    Once engine start do what I already suggested.
  • 315 Answers
Hi, this issue might occur due to the pressure variance by the unloader/pressure regulator valve or slipping belt on belt drive systems. Worn packings in the unloader will not maintain pressure. Try lowering the pressure to 1000 psi then slowly increase until problem reveals then lower pressure again to maintain steady stream. This problem can also develop if the wrong size tip is used in the gun. Example, if output rating is 3000 psi at 4.5 gal per min and you are using a tip for 3000 psi at 4 gpm. The unloader will release causing variance of pressure. Easy way to lower pressure of system is to increase the size of the tip to 5 or 5.5 gpm in a system rated at 4.5 gpm. This will help!!
Spray nozzle leaks
That would be your best bet very well could be a bad sprayer housing
Jan 23, 2018 | Rohl Plumbing
The freon is fully charged but the air keeps getting warmer until there is no longer any cold air. It still blows air but it's warm. Does this sound like the compressor is bad??
do you have to recharge it after it starts blown warm if so its just got a leak and leaking all your freon out if its holding all freon then compressor must be bad
Sep 14, 2012 | Air Conditioning and Heat for Isuzu Axiom
Sprayer hose leaks at the base of the faucet after sprayer replacement and thread tape application
Make sure the internal washer is intact and there is no damage to the parts that you are connecting together. Also, do not use too much tape....one or two winds is enough and wind in in the direction of the action of the female connector (clockwise) so you don't bunch it up in one spot.
May 05, 2012 | Plumbing
Airbag leak
this is hard to say without knowing what type of car, i will assume its a lincoln, the most common problem is with the air bags, if this has been a problem for a while in which the car would lift up after starting due to a leaking bag then i would say that you will need a new compressor also. what happens is the compressor runs until it gets hot and goes bad, sometimes the fuse will blow before the compressor goes bad, you would need to check fuse in the engine compartment.
Feb 17, 2012 | Cars & Trucks
1998 T/C rear goes down while car is parked. There is an odor similar to hydraulic fluid. When car starts, compressor runs and rear levels; stays level until motor turned off.
More than likely your rear shock(s) have leaks that cause the compressor to reinflate. A possible explanation for the inflation to only occur while the engine is on is so the battery won't be drained during down time. Probably a protective feature. As for the hydraulic smell, check for signs of leakage under the hood and under the car. Also check your engine coolant for possible leaks.
May 07, 2011 | 1998 Lincoln Town Car
I have a SMITH aircompressor with a 460 7.5L engine it around a 1980 year model the carb needs to be rebuilt where can i get a rebuilt kit for it?
I worked for a tool rental company while attending college and learned a great deal about engine /compressor combinations. AOSmith compressors used mainly ford engines to power their reed valve compressor head. The mechanic would use off the shelf carbs from local auto parts store. I would recommend that you remove the carb looking for an id tag or numbers stamped on the carb body to cross refrence it for rebuild kit or just exchange. The carb will not be for a 460 engine however. Since 1/2 of the engine is used for pumping air, the carb will be for an engine of lower displacement. We also rented a brand called Lindsay that used a Chrysler eight cylinder engine with their own design of reed valve head. These compressors would work pretty well untill the reeds started leaking, causing the engine to labor. Easy test, with engine off apply compressed air to discharge port (100psi), with cover removed from compressor head, listen for air escaping past reeds. Repair as needed.
Mar 29, 2011 | AO Smith Air Tools & Compressors
My 02 sonata a/c system doesnt blow cold?
Ok... you wrote "lock was all dry but after i charge the system it start leaking from the same place that the original was leaking,(center of ac compressure.)" Sounds like you should have 'OVER HAULED' the existing/used compressor before installing it... OR bought a recondition/new compressor (ya think?). It appears both the original and used compressors have the same defect.
Jun 24, 2009 | 2000 Hyundai Sonata
Windscreen washers not operating correctly. Water comes thru the jets but at low pressure
Get yourself a small gauge/thin piece of wire. Poke the jet holes with the wire until they spray like they used to. If you have an air compressor you can also blow through the sprayer with compressed air after poking them with the wire and they should be good as new. If that doesn't work you might have a blockage in the line at the one-way valve or at the pump in the washer tank.
Nov 28, 2008 | 2003 Hyundai Santa Fe
Honda Pressure Washer PSI 3000 Logo
214 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
