Question about Apple iMac G4 Desktop
Thanks for the help!
Hi,guys my g4 imac is frozen. I've done numerous things,like restart on v mode or single mode.The imac tells me the problem,which is memory!If i take the four screws of the bottom and install a memory card.Should that help? Thanks Bobby from Houston,TX
  • 143 Answers
That sounds like it would fix it. Have you recently updated the memory in the imac? It may be incompatable. Otherwise it may simply have become faulty over time.
Please make sure that before you open up your imac, you're not voiding your warrenty. I know that the aluminium imacs allow this, but i dont think the G4 versions do.
Hope this helps,
Nathan.
Posted on Apr 14, 2009
My imac does not start white screen with a ? mark
reset pram,
try holding down s key to boot in safe mode,
try holding down option key on startup and select drive,
install system disk and restart holding down c key.
Feb 09, 2014 | Apple iMac G4 Desktop
Reboot without a disk
You may have to go to single user mode and start from the terminal. Difficult. Otherwise, zap the p-ram by holding down the Apple Option, P and R kets at the same time after you here the chime. This should reset enough to get you running. Maybe. Or, hold down the shift key will restarting to start in safe mode. Or, hold down the option key will restarting and select your start-up drive from the menu,
Feb 24, 2013 | Apple iMac G4 Desktop
Imac g4 freeze restart
This is a sign of memory issues with your Mac. Replacing the memory should not be very expensive.
Oct 10, 2012 | Apple iMac G4 Desktop
My monitor on a macintosh Gf is black since setting the resolution toohigh. What can I type in or do to get the resolution to decrease even though I cannot ee the scren as it is black? Thanks, Rochelle...
You could try resetting the PRAM which resets various things to default status. You do this by holding down the following 4 keys together "cmd" "option" "P" "R" at the startup sound, keep them held down until it restarts and keep holding them down until you hear the startup sound 2 more times and then let go.
If that does not work try booting up in safe mode by holding down the shift key at startup and then when it boots up change the resolution to one that works and then restart.
Hope this helps.
Jan 27, 2012 | Apple iMac G4 Desktop
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
May 18, 2010 | Apple iMac G4 Desktop
Hi ihave apple power book g4 i want reboot
login in single user mode as below:
Starting up in single-user or verbose mode
    1. Shut down the computer if it is on.
    2. Press the power button to start the computer.
    3. Immediately press and hold the Command (Apple) key and one of the following:
    • the "s" key for single-user mode. (Command-S)
    • the "v" key for verbose mode. (Command-V)
You have successfully entered single-user or verbose mode when you see white text appear on the screen.
Once you are in the Single user mode type the following:
fsck -fy <then press enter>
If this command returns with an error or reports that is found an error but fixed it then run the command again and repeat until the drive checks good.
Once you are done with the repair or feel satisfied, type 'reboot' and press enter.
Feb 12, 2010 | Apple PowerBook G4 Mac Notebook
Active window goes inactive by itself
A lot of people are experiencing similar behavior due to bug in Stuffit, if you have it installed, go into System Preferences -> Stuffit -> Disable AVR. I only mention this because it has been the prevalent cause this week.
If that isn't your issue, Then...
Resolve startup issues and perform disk maintenance with Disk Utility and fsck
Mac OS X: How to start up in single-user or verbose mode
If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...
What is Safe Boot, Safe Mode?
Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack
Another excellent free tool for performing maintenance is Onyx (be sure to download the right version for your system). Install the package, then run it, it will check your drive and the structure, after this, click on the automation tab and check on everything for Maintenance, Clear Cache, Cleaning, and check on Reset -> LaunchServices database and Mail's Envelope Index. When it completes, restart. Repeat any time something seems flaky, if not try to run at least once a month.
Jan 30, 2009 | Apple iMac G4 Desktop
My computer completely rebooted and i cant get to the log in, what do i put in to get to the main frame
Try holding down the shift key after you hear the startup chime. This should start the Mac in Safe Mode and force some cleanup utilities to run. (Note that startup takes a bit longer than usual in Safe Mode.)
The login screen should show the words Safe Mode in red when startup is done. You can then restart and the Mac should boot normally.
Nov 24, 2008 | Apple iMac G4 Desktop
Imac question
Try turning it on with the shift key down. This gives a safe boot. If it's going to turn on at all, it will turn on then. Also, boot it with Disc Warrior or Tech Tools and run some tests to see what is going on. I hope you find all is well, and that the repairs are just minor. Good luck.
Sep 19, 2008 | Apple iMac G4 Desktop
It won't turn back on
Change the power supply to start. If the supply does not fix it, the mother board may have a fault. Most of these types of failures are in the power supply.
Jerry G.
Jul 07, 2008 | Apple iMac G4 Desktop
Apple iMac G4 Desktop Logo
157 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
