Question about RCA D52W19 52" Rear Projection Television
RCA HD TV MOD D52W19
WILL NOT COME ON
  • 10 more comments
  • dawad Nov 05, 2007
    TV light go on for a couple seconds than goes off? is it the bulb and is it worth repairing
  • Anonymous Nov 18, 2007
    on button blinks a number 19 code.what does this mean
  • itybity Dec 05, 2007
    we replaced the fuse behind the power cord....hoping it would solve the problem of not turning on... did not solve the issue...
  • stephenking Dec 12, 2007
    will not start up
  • Anonymous Jan 06, 2008
    Tv cuts on and off . It seems like the power is shorting out or something is loose and then it will just turn off.
  • Anonymous Feb 14, 2008
    TV is not turning on and the power is flashing a green light numerous times then nothing
  • Bolomed Feb 23, 2008
    Tv will not turn on, the green light comes on for a few seconds, and then goes off.
  • Anonymous Feb 27, 2008
    THE
  • HUGGINS Feb 27, 2008
    THE GREEN LIGHT COMES ON AND TURNS OFF SEVERAL TIMES AND THE TV WONT COME ON SOMETIMES IT TAKES HOURS TO GET IT TO COME ON
  • Anonymous Mar 06, 2008
    tv will not come on
  • Anonymous Jul 07, 2008
    my tv when you put in no automatic change off
  • lifeloverfl Aug 29, 2008
    How much is a new SSB board for this HDTV and where can I purchase it?
T.V wont turn on!!When i plug it in the green in front blinks 9 time short pause then 5 times. what could be the problem? Worth fixing?? Anwsers please
Posted on Feb 15, 2008
Thank you this site rocks this was the first time i had this problem i heated up the board with a hair dryer until it turned on. i will remove the board later and have repaired.
Posted on Mar 18, 2009
This fix is for those situation when the set light comes on and then shuts down soon after due to board voltage limits issues.
The follow fix worked for me and may work for you.
>>> DO NOT ATTEMPT IF YOU ARE NOT EXPERIENCED ON WORKING ON LIVE COMPONENTS AS THERE ARE POTENTIALLY DANGEROUS VOLTAGES INSIDE A LIVE SET THAT CAN CAUSE GREAT HARM IF YOU TOUCH THE WRONG COMPONENTS INSIDE!!!<<<
Over/under voltage signals will put this set in shutdown mode and can happen during a cold startup. The fix was at least $400, not really worth the money. Instead of junking the set I unplugged the board to board plug (should have 10 to 12 wires in the plug) so no shutdown signals would get through during initial startup. This was found on right side on vertical board, you can find a schematic on line. I turned on the set, the transformer came on warmed up and settled down. I was then able to plug the board back together while the T.V. was on and it works fine. I now leave the set on and change the input mode to an unused mode when I am not watching the T.V. or my kids are not playing their video games. If the TV fried, it was no big deal, it was junk to me anyway.
Posted on Mar 02, 2008
    Genius:
  • 1,030 Answers
The RCA ITC222 chasis is a shutdown prone set. I deal with this television alot in the shop. The first thing too know is this set's microprocessor will shut the set down for 1 of 20 different reason for safety. The fact that the light comes on tells you its not the main fuse. ANd the processor is recieving power. It is detecting a problem with something else.. I have found high voltage issues to be the most likely problem but like i said can be many things. The first thing as a customer you can do it to reset the processor. uplug the set for a minium 30 minites and try it again(note i dont think i have ever seen this work) As a tech the next thing to check is the Horizontal output transitor. see if it is shorted. if those are ok.. then the troubleshooting begins.. The processor on these set record the failures and a technician with a special interface can read these codes to help. Some of the cuircits invovled also require this interface to replace.(SSB BOARD)
Posted on Feb 08, 2008
I had the same problem when I first bought mine. It requires a huge amount of electricity. Try and only use one outlet by it's self. I had a lot of other stuff on the same outlet, unhooked everything but the t.v., and tried again. Bingo! it worked
Posted on Apr 06, 2008
3 Suggested Answers
SOURCE:
Slinteriors
  • 8617 Answers
SOURCE: rca tv wont come on at all
Look on the back for the chassis number. RCA and phillips need the chassis number to be diagnosed.
Posted on Feb 02, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA HD TV D52W19 does not turn on
Replace CP150 , CP120 and CP114. You can get the repair kit at www.tvrepairworld.com that has the capacitors and detailed instructions. Look under the RCA repair kits catagory.
Posted on Aug 28, 2009
When using PS3 on RCA D52W19 TV, the screen does not fit ( it is zoomed and off-center) in 1080i resolution.
hello!
Have you tried to toggle "format" or "screen size"? On those sets non HD and HD settings could be adjusted separately. Try that, first. If no luck, try similar settings on PS3. I bet, you will be able to match screen format there, as well. To me it looks, like picture formats are mismatched. Also: try to use "component" cables, instead of DVI adapter cable, if nothing works.
good luck,
Alex.
Feb 16, 2012 | RCA D52W19 52" Rear Projection Television
We have a RCA D52w19 rear projection tv. It appears that the HD feature is not working. My Wii does not recognize it as HD and the picture for Wii, satellite and DVD is noticeably grainy. Is there an easy...
The Wii is not a HD output source. It only displays 480p. If you wish to connect an HD source, you must connect through an HDMI cable or a component Cable. HDMI is better.
Feb 28, 2011 | RCA D52W19 52" Rear Projection Television
Our RCA D52W19 TV is playing in standard 480dpi (Satellite, DVD, and Wii). How can we get it to play at 1080dpi, like it used to?
I have a RCA Home Theatre, gemstar guideplus gold. I think it is a 52" rear projection. I just want to know is it a HD TV?
It does not have an HD or ATSC tuner. But it does have HD resolution inputs - ie HDMI and component video (RGB) so effectively it is HD
Nov 24, 2009 | RCA D52W19 52" Rear Projection Television
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
Rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
Rca hidef tv
Most likely a bad power supply module. The 3 tries is the 3 strike rule with the RCA TV's.
May 26, 2008 | RCA D52W19 52" Rear Projection Television
ok 4 months was it brand new when you go it. it may still be under warrenty. but chances are you have shorted out some high voltage component. averge cost to repair at my shop is 350 to 500.
Apr 03, 2008 | RCA R52WH73 Projection Television
RCA D52W19 52" Rear Projection Television Logo
1,021 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
